Keep seeing references to the rp number in parts books etc but I can't find it on my 96-97 xant there is a yellow stencilled number on the bulkhead in front of the driver (kjwcr no numbers) but it doesn't start with RP.
Any ideas where else it is ?[V]
Where is the RP number
RichG
The RP number on my 1998 Xantia is in the position that you describe looking from the front of the car with the bonnet open. The numbers should be there but they may need some 'interpretation' as the French stenciller is not too careful about the quality of his work! It should start 'RP' followed by 4 numbers.
Jon
DLM
This should be a 4-digit number, which tell you the exact date of manufacture of your car.
see http://www.tramontana.co.hu/citroen/mai ... ORGAscript for the principles
It was seen on BXs by opening the left-hand door and looking at the A-pillar. I heard it had moved for Xantias - but only to the other A-pillar from what I remember.
There'll be a Xantia owner along shortly to correct me.....
DLM
paranoid
