I believe the regulator is electronic and there is only one element. I say this as the control "rheostats" are not rheostats at all but switches that switch in different values of very small resistors. The "rheostats" connect to the seats via very light gauge wiring.
The regulator box is buried in the seat. Never cracked one open to see what goes on inside it.
That yours work on the high setting only suggests the regulator is bypassed for high.
Fitting Electric Leather Seats into a Xantia
- x 8410
eskerman
Re: Fitting Electric Leather Seats into a Xantia
I have a 2001 Xantia with the standard manual seats and I recently managed to secure an Xantia 2000 - HDI but with leather electric seats (its a donor car) .. I may consider swapping out the leather seats--- . just wondering if there is a connection anywhere in the wiring loom for the seats -- or do I have to hard wire a new power supply to the seats..
I want to avoid too much "surgery" and pulling the interior apart -- if at all possible
Thanks in advance
Paul
Thanks in advance
Paul
- x 1463
The wiring harnesses are specific for electric seats, so you car won't have a suitable connector.
Some have wired them to the lighter socket, others to the ignition switch or jumper link on the fuse board.
admiral51
- (Donor 2026)
- x 391
The donor car will have the loom and from memory the fuse box is drivers side so a decent Auto Electrician should be able to work something out.
Yes the under bonnet fuse box is passenger side but the feed to the interior fuse box is under the scuttle panel on the drivers side ?
Colin
Colin
