hello,i have a se1 xm v6 auto 12v a/c
had some work done on the auto,everything works well
but when it came back the revcounter did'nt
would someone please be able to tell me where the rev-c picks up its signal
so i can go from there thanks
xm revcounter
citroenxm
- Fallen Hero
- x 70
Hi..
Thats a strange one, the rev counter takes it signal from the Flywheel pickup sensor ontop of the gearbox, right up against the heads, under the throttle inlet ..
I say strange because if the sensor wasn't working, then the engine wouldn't run as the ECU uses it as a Flywheel position - so it knows were TDC is..
It has to be a connection further down the line some where.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
