Had to jump start my '05 206 this morning. After doing this the engine kept revving to around 4000 until I touched the accelerator when it dropped to 1000 revs then jumped to 2500, and keeps doing this. Do I need to reset the BSI or is there something I'm missing?
Stephen
206 Battery Jump Start
chemexhants
1997 ZX SX 1.9TD 140k miles
- x 94
if its a petrol car it could be the throtle idle control stepper motor playing around,
i would try switching the ignition on and off a few times without starting the engine,
this might reset the stepper motor,
or did you conect/flash the jump leads up the wrong way to start with as this might upset the ECU
regards malcolm
regards malcolm
Oldpug
- x 94
chemexhants
Thanks for the replies. The problem has now corrected itself.
Spoke with a Peugeot techie who says that the BSI wasn't woken properly by simply jump starting. I should have turned on the sidelights first to wake the BSI unit and then started the engine. That overcomes the problem.
Also, before disconnecting a battery everything should be turned off and 3-4 minutes should elapse before disconnection occurs. That way the BSI will shut down correctly.
spider
- x 77
This is truechemexhants wrote:Also, before disconnecting a battery everything should be turned off and 3-4 minutes should elapse before disconnection occurs. That way the BSI will shut down correctly.
Andy.
