ZX: diesel consumption
ZXturbo_Aura
Unread post by ZXturbo_Aura »
whats your average diesel consumption in a TD?? mine seems quite low, about 40ish?sometimes high 30's, i this just my drivin or something else?
thanks,
DAn
Brian Oblivion
Unread post by Brian Oblivion »
Mines 49 mpg so far in a 1994 ZX Aura TD with 63k on it.
If you still think you are immortal i.e. below 28 yrs of age knock about 10 mpg off what you should be getting!!
ZXturbo_Aura
im only 17... must be that then!lol, i'll be nocking off 20mpg then! thanks for the info, just wanted to make sure i wasnt loosing any etc
thanks,
dan
Kowalski
Unread post by Kowalski »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Brian Oblivion</i>
I'm under 28 and average 43 Mpg in a Xantia mostly on the dual carriageway. Limiting my top speed to 60mph got my average up to 48.
Guru Meditation
Unread post by Guru Meditation »
Just done 54l in 441 miles so worked economy out to be about 37mpg, I could cry that's so poor :-(
David W
Unread post by David W »
Our 1993 ZX TD 5dr never drops under 40mpg, 43mpg most local use and perhaps 47mpg on a brisk long run.
I thought only heavily caned Xantias would go well under 40mpg!
David
Paul Thomas
Unread post by Paul Thomas »
My 1993 ZX TD with 116,000 miles on the clock regularly returns 45-50MPG on supermarket diesel ! And it ain't driven slowly either !! (Within the speed limite of course Officer)
Guru Meditation
I know I don't understand how the hell I get it so low. This was with a bottle of Wynns injector cleaner in it too. For the first 200 miles or so it was a run to Birmingham and back, averageing >70 but <85. The rest was mixed driving around Peterborough so mainly parkways with some in town stuff. My driving style is I'd say reasonably push on ie I always seem to be leaving 'slow' traffic behind but I rarely put the pedal to the metal so to speak and rarely travel above 80mph. Maybe 20 or so miles out of the tankful were spent driving properly hard with full revs through the gears.
Jon
Unread post by Jon »
Anything over 3500RPM in 5th and your fuel consumption is likely to be in the late 20's. I know.
[:p]
I do from my house to Birmingham and back 3 days a week thats 208 miles a day on 1/2 a tank per time..When I set off again the next day £15 is enough to get it there and back again!! I think thats pretty impressive really. Thats keeping up with M-way speeds as well, not poodling along at 55mph in an economy run or 3 figures in the other extreme. Sort of 75ish to the odd 90 I suppose.
PS I am 36.
Paul Thomas
3500RPM in 5th.
What does that work out to in MPH ??
s1zx
Unread post by s1zx »
Aparently you should get 47.5 mpg in a zx 1.9td depending on conditions and loading .
on a side note my 1.4i zx gets about 40 - 42 mpg and i live in a pretty hilly area am under 28 and um dont hang about so maybe speed doesnt mess up zx mpg that badly
bencowell
Unread post by bencowell »
I found that my C5 HDI 110 can have a greater variance of economy than my previous Xsara 1.4.
oilyspanner
Unread post by oilyspanner »
Compared to both of my BX TDs My TD Volcane drinks like a fish, sub 40 (though I am 40 plus) if that makes any difference?
Stewart
Stuart McB
Unread post by Stuart McB »
Recently worked out 52MPG in my 146K ZX TD on an L reg. Thats in to Birmingham and back to Worcetsr every day with out speeding.Not using the motor way. Oil consumption is a bit high since service though.
philhoward
Unread post by philhoward »
As a slight aside, my Xantia TD has just done 47mpg on a tank full; driving with the traffic thorugh the rush hour, but trying not to go over 2500rpm before 5th gear admitedly!
My last Xantia TD wouldn't get over 38mpg (although it was quikcer), so I think some cars are just better than others..
