Hi all
On the alarm ECU in my VSX there is a lone wire that comes out of the main loom going into the ECU, that has a single in-line connector, which isn't connected in my VSX, or an SX in my local scrappers - both have tow-bars if this is related in any way?
Does anyone know what it does and why it might be disconnected?
Cheers.
Cable going into alarm ECU
OnlineCitroJim
- x 8468
If on a MK1, Ive seen the connector and not really worried about it. I believe it's an earth and used only with heated electric leather seats... There are many spare bits of loom running around a Xantia...
If it has a number on the wire, I can tell you exactly. If the number begins M (for merde) then it's an earth.
If everything works, I'd not worry. Nothing to do with a towbar. All the factory wiring for that is in the boot...
atr
- x 6
OnlineCitroJim
- x 8468
There is on my MK1 Activa. I noticed it purely by accident when I had by boot carpet out the other day. The towbar wiring is neatly plugged into a socket on the RH rear inner wing by the air vent box and there's not a Scotchlok to be seen.atr wrote:CJ - did I understood right? do you suggest that there is a prepared connection for towbar electrics?
I'm not sure if this is universal or present in the MK2. I've not consciously seen reference to it in wiring diagrams. I'll have a look later...
addo
- Sara Watson's Stalker
- x 95
Dommo
- x 20
quintet
- x 44
My MK1 LX has this wire too, I'm guessing the wiring loom in question is basically a universal wiring loom used across the Xantia range (easier & cheaper for citroen to produce/make one loom type to suit all models rather than several different ones), if this wire is for the seat then it's simply an unused earth, if you had a bit of a root around you'd find a few 'unused' wires/connectors throughout the car.
Music keeps me going.
