407 HDi 2.0 136 ...........hellllllllllppppppppp!!!!!!!
pugsick
Unread post by pugsick »
Hi, new to the forum so do please bear with me. I have an 04 136BHP 407 and for the past year (yes year) i have had the following problem. Every 4/600 miles the engine sounds flat and deep. It hesitates badly and feels very lumpy. When this happens i have 2 x options. Drive very gently and it passes or drive as normal and the MAGICAL engine management light comes on. If anyone could offer me any assistance i would so so grateful. Love the car but driving me mad. As a result i never drive above 3k revs and know i am missing out on so much more fun. Thanks again in advance for any help given.
x 1499
How many miles has it done? It sounds like it is going to regenerate the FAP, but there is some problem. Has the FAP been cleaned, and has the fluid been topped up, or has it been frigged?
pugsick
mileage???? are you ready... 147500. I know its high. I am am having it code read tomorrow. Will this be of help? Thank you for your reply.
spider
x 77
Unread post by spider »
That mileage is nothing (honestly) for a maintained HDi unit. :)
Andy.
pugsick
such a relief to hear that.. Realy is. Great looking car just damn electrics let it down. So badly want to use the 'rev' range. Would it help if i got the falt codes?? Also (sorry to sound dumb) what is the FAP please.
Chris56000
Unread post by Chris56000 »
Hi!
The FAP (its a French abbreviation!!!) is a particulate filter that fits in front of the catalytic converter and is used to burn the emitted particles into fine ash by a high-temperature regeneration process initiated by the engine-management control unit.
When the vehicle reaches the specified mileage, a warning of this is shown on the Driver's centre dash display along with the illumination of the engine management indicator light, and the specified procedure to initiate the regeneration is to drive in 4th at about 70-75 mph at an engine speed of about 4000 RPM for at least fifteen minutes.
The FAP filter has sensors at each side of it which monitor the pressure-difference across it and when a blocked FAP unit results in the pressure difference exceeding the maximum limit set by the engine ECU, a fault code will be set and a warning displayed.
The dealer procedure for clearing the fault is to simply replace the FAP with a reconditioned unit, but it ***is*** possible to remove them and blast them through with a high-pressure water-jet at home.
The Fuel Additive used in the FAP regeneration process is a cerium-based compound called Eolys Fluid which burns at a very high temperature, and a small amount is injected into the fuel tank by the additive-control ECU each time the fuel-tank is refilled, and it is stored in a small plastic reservoir fitted at the back of the fuel-tank. The centre display will indicate "FUEL ADDITIVE LOW" when this Eolys container needs refilling - I think it needs doing every 48,000 miles!!!
It ***is*** possible to buy this fluid in a bottle yourself from fleabay with instructions and a refilling kit, but I ***MUST*** emphasise that this compound is ***extremely corrosive and poisonous*** and must only be handled with the utmost care and respect!!!
Any of the chappies on this Forum who have PP2000 tackle can reset a Particulate Fault by the way!!!
The PP2000 can also be used to initiate a forced regeneration in locations where a long-section of high speed road isn't readily available, but I've heard that this actually can produce flames, sparks and all sorts of things out of the exhaust whilst the procedure takes place, and the engine's timing belt ***MUST*** be in good condition before attempting the procedure as the engine needs to be accelerated to maximum governed speed for an extended period of time to carry it out!!!
Hope this helps!!!
Chris Williams
pugsick
Thank you for your help. When i first got the car i had to have the particulate filter replaced and Eolys fluid was also topped up and its still been the same since.
x 1499
Sounds like you need to get it on a proper diag computer - preferably when it's trying to regen to try and see what's wrong with it. It would be better if you can read live data to determine why it's going haywire - however, letting the light come on and reading the fault codes (again with a decent machine, not a generic scanner!) might point to the fault. Unfortuantely I can see this going one way - the way that involves ££££ :x
siwy24
Unread post by siwy24 »
hey had similar problems with my car and cleaning the FAP actually helped. The FAP is a good suspect.
If you have it connected to PP2000 it might help when you read the faults and codes.
Chris56000 nice one :D
pugsick
Thank you every one for your help. I am having it code read at the weekend and I will post the results over the weekend/ Monday. Thank you for your thoughts. I will keep you posted.
pugsick
Hi , just an update. Having driven some 260 miles yesterday an 'nip' to the shope this morning proved too much and the magical 'depolution system faulty' warning came up. God i hate that 'beep' sound. You just know whats comming......
I had it code read straight away and the following came ip;
D118
1445
1350
1351
0096
1693
Any help anyone can offer much much appreciated...
pugsick
Ahhhhh, my car
can anyone offer any help/ suggestions on this...... any help appreciated
pugsick
Peugeot specialist????
Hi i wonder if anyone can suggest a good peugeot specialist in Hampshire/ Surrey. If you have read my threads you will see i have had 1 or 2 problems (3,4,5,6,7,8etc) and really want to get it back running how it should. Any help appreciated.
MikeT
x 232
Unread post by MikeT »
If you can bring it to Christchurch, I'll run the Peugeot dealer diagnostic tool over it for you. It should give more meaningful insight than a bunch of OBD generic codes, though beyond that I can't promise anything.
pugsick
Thank you
Really?? that would be great. I'm stuck with using the plug in 'clear fault code' error hand held. Short fix but no solution.. Just want to get it working how it should.
