Hmm, thanks but I was really after an estate for the additional room in the boot for general lugging about, HDi's don't frighten me as I have a Lexia and a number of useful new/used spares if necessary for substitute testing and HDi 110's don't suffer turbo lag like my TD.KP wrote:Dickie there is a Hatchback non-HDi close to you for a decent amount of cash that could have some work done to it with your skills and server you well maybe? less complex than a HDi too
Tales of a C3, a Goddess and some BMW's.
DickieG
- Monaco's youngest playboy
- x 33
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Citroenmad
- x 110
Its a shame you had a wasted trip to view that very nice looking Xantia. Just shows that pictures dont give you the full condition of a car! Ive been in that situation a good few times, ive done many miles driving around the country looking at 'immaculate' cars which turned out to be scrappers.
I went to see a Xantia HDi Exclusive late last year, a couple of hundred mile trip. It was awful, they had it described as a good car, they failed to mention that some panels had been sprayed with a rattle can, the clutch was just about slipping, spheres were knackered, sport suspension didnt have any effect, etc etc. I got offered it for very little money after pointing out the obvious, but it wasnt worth tidying.
Good luck with your search, it does show that Citroens are hard to beat though!
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1496
Best of luck Dickie - I spent 15 months searching earnestly for a decent HDi estate 3 years ago before I bought my current one - not even a sniff of an Exclusive - let alone a decent one! Mind you, there are more down your end of the country that there are at mine.
On the BMW can you clear the fault codes then take it for a short drive and look for a first up fault code - or even better watch the live data for the tell tale signs. Mind you the multiplex might hide all sorts of things - or indeed be the fault itself. Modern cars - great when they work, headache when they don't
DickieG
- x 33
Well a stroke of good luck today as I managed to borrow a Bosch KTS 650 diagnostic computer from work for the evening, wow what a useful bit of kit, for a generic tool it certainly covers a wide range of car's and goes into a reasonable depth on each one as well although Citroen Hydractive suspension isn't on it
mind you bearing in mind that they cost something like £6K they have a right to be good. Its appearance is similar to a Lexia 2 with a touch screen but compared with the operating speed of a Lexia the Bosch is a greyhound as it whizzes through each system very quickly.
Anyway how about this for a bunch of codes caused by a non reading N/S/R ABS sensor, one engine code, two ABS codes, five Gearbox codes and five instrument panel codes
. When I test the faulty sensor individually using a multimeter it checks out OK but when on the vehicle it fails to read the wheel speed, the sensor wasn't dirty or suffering from an extra large airgap so I presume at this stage that the sensor is simply duff so I'll source a new one asap and see whether that sorts the problem out. The great thing about decent diagnostic equipment it can display the readings from each sensor during operation so using ABS as an example I brought up on the screen the live data being recorded from each wheel sensor and discovered that the N/S/R was reading nil whilst the other three were recording the same speed.
It never rains but it pours, when I returned home this evening after picking up my daughter following after school lessons I noticed that my remaining Xantia is making a right old racket when at idle as if some heat shield is rubbing against an engine component, with time being precious this evening I put it up on ramps and had a poke around but couldn't locate the source as I need to remove the undertray to gain full access. As soon as the engine speed picks up beyond 1,000 RPM the noise goes away so at this stage I presume/hope its nothing sinister, oh deep joy at this rate I'll be using the Goddess to get to work soon as my other car's decide to fall apart
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8430
DickieG
- x 33
DickieG
- x 33
Success with the BMW, I picked up a new ABS sensor on my way home from work, fitted this evening and following a test drive the gearbox is operating normally. Fingers crossed the repair lasts otherwise the car may end up as a burnt out shell (once I've removed the sat nav and TV as they fetch a decent price on Ebay)
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
XantiaMan
- x 18
Time to get rid and get a very nice Xantia (if you can find one)DickieG wrote:Success with the BMW, I picked up a new ABS sensor on my way home from work, fitted this evening and following a test drive the gearbox is operating normally. Fingers crossed the repair lasts otherwise the car may end up as a burnt out shell (once I've removed the sat nav and TV as they fetch a decent price on Ebay)![]()
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
2017 Fiesta ST
DickieG
- x 33
XantiaMan
- x 18
Most bizarre that we have both come full circle, kinda!:lol: Wont be using my Activa as my only use car which means i can play and learn a bit more about themDickieG wrote:My plans exactlyXantiaMan wrote:Time to get rid and get a very nice Xantia (if you can find one)
Although i have been lucky with the Mondeo and had no problems in 10k and enjoyed every second, its one car i wouldnt sell.
Looking forward to the next FCF meet, as its been a while.
2017 Fiesta ST
2017 Fiesta ST
red_dwarfers
- x 58
You only just missed out on the Duxford IWM meet a few weeks ago. That was pretty damn good, quite a drive for me though!XantiaMan wrote: Looking forward to the next FCF meet, as its been a while.
Pics
A few FCFers will be meeting up at the classic car show at the NEC.
Kev
'19 C4 Cactus 130 Flair
DickieG
- x 33
Are many going to that and if so what day? Having just looked at the show website why is Friday £5 dearer than Sat/Sun (as if £20 isn't enough anyway)?red_dwarfers wrote:A few FCFers will be meeting up at the classic car show at the NEC.XantiaMan wrote: Looking forward to the next FCF meet, as its been a while.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 8430
- x 1496
Bit easier than a Xantia then....you wouldn't have tackled that in an evening in the dark cold and wet!DickieG wrote:I picked up a new ABS sensor on my way home from work, fitted this evening
At least you got access to some decent diag kit, and weren't left to the mercy of the 'experts' at the dealers!
citroenxm
- Fallen Hero
- x 70
You can do this With Lexia 3 aswell, I have recently driven around with a laptop on the passenger seat reading the Live data from the sensors... interesting in that they read a faster speed then the speedo - of course due to drive shaft size...DickieG wrote:
Its in the Parameters section...
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
