Xantia Keyfob - Saxo Keyfob
jmd
Unread post by jmd »
Two questions .
(1)The Keyfob on my Saxo is faulty. I have insertrd several new batteries which die within 24 hours. This I put down to a faulty fob. Is this problem curable & how ?.
(2) I have a keyfob for an usused Xantia. Can this Fob be programmed for the Saxo ?.
x 8309
(2) I don't know the answer to but (1) could be one of the push-button switches being permanently held down. Might be worth taking it all apart and checking that the rubber parts are not holing the yellow tip of the button down...
jmd
Tried that one CitroJim and the buttons are free. but obviously something similar would appear to be happening, when the batteries are continually getting drained.
x 5652
Try holding it in front of a digital camera (not SLR) and see if the IR LED glows constantly.
x 1929
myglaren wrote:Try holding it in front of a digital camera (not SLR) and see if the IR LED glows constantly.
What an excellent tip. I knew that IR can be picked up by CCTV cameras but hadn't made the logical jump to include the now ubiquitous digital cameras.
Old-Guy
x 24
Unread post by Old-Guy »
Ah, but not all digital cameras are equal!
I've discovered that not all digital cameras can 'see' in near IR. My elderly phone camera, antique Fuji camera, and older Nikon all do, but my dinky new Nikon ultra-compact doesn't. May be to do with its incredible sensitivity - I can use it as a colour image intensifier in the deep dusk when I can only see in shades of grey.
It's a handy trick for checking IR remotes, but test the camera first!
Jaspwieser
Unread post by Jaspwieser »
IR light will only be picked up by a camera with a mono (black & white) chip.
:roll:
x 1929
I think it may be more to do with whether the camera uses CCDs or triple CMOS detectors. I think that the better cameras now use triple CMOS.
JamesQB
x 5
Unread post by JamesQB »
IR will be detected by most digital cameras and mobile phone cameras. Although most have an IR filter in place in front of the lens, some IR gets past when using a direct source like an IR LED. I've tried many digital cameras and mobile phones, and all so far detect IR readily, as a white light (because it equally excites red, green and blue pixels).
You could build this, which I made and works well:
Great for checking remote controls (dunno about keyfobs, are they 38KHz?). Parts easily got from eBay or Maplins, etc. For the IR detector, you can just grab almost any 3-pin type from an old TV, VCR, DVD player, etc.
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
