How much LHM do I need?
DHallworth
x 166
Unread post by DHallworth »
How much LHM will it take to fill the reservoir on a Xantia HDi if it's completely empty?
I've just emptied the reservoir on ours and am going to put clean fluid into it.
Just wondered if anyone could give me a rough idea in litres of what it'll take to fill it!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Hello David, when I drop all the spheres and remove the reservoir to clean, it seems to take a little under four litres. If you bleed the brakes and whatnot, it might expend another cupful.
andmcit
x 30
Unread post by andmcit »
Dammit Adam, that was fast, I was going to say 3.5litres!
Andrew
VertVega
x 13
Unread post by VertVega »
Only the reservoir would be around 3.5-4 liters I guess.
Edit: Never filled only reservoir. I would recommend a full fluid replacement.
Recently I gave a Hydraurincage treatment to my Xantia. LHM flushing fluid comes in a 5 liters container.
About 4.5 liters is used including brake bleed process.
I bought ready 5 liters of LHM+ for my next LHM change 8-)
Chris570
x 36
Unread post by Chris570 »
i always buy 5 litres so that i have some spare to put in the boot :)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
DHallworth
x 166
Thanks guys.
I am doing a complete flush on the system so will buy 5 litres just to be safe.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
