During a routine inspection yesterday I noticed a fluid leak on the power steering rack had become noticeably worse.
It was more of a heavy mist 6 months ago but is now wet with LHM at the nearside.
Has anyone replaced the seals on this and if so how easy is it to find the parts and how difficult to do ?
Xantia HDI power steering rack leak
HDI
- x 7
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 8310
Whereabouts exactly is the leak coming from HDI?
The ram can leak and if it does then it's a new ram if the ram seals themselves have failed. A ram leak will be indicated by the plastic bag that protects the ram piston being wet with LHM. On the end of the ram is a leakage return collar which is not normally replaceable but an XM one (of the sort I use for Activa Ram repairs) will fit.
Another favorite place for a leak is in the pinion return line where it changes from a metal pipe to a rubber hose. The rubber hose can split on the joint or on the corner where it turns sharply upwards on its way to the LHM reservoir.
HDI
- x 7
Yup, it's the plastic bag section !
Surely the seals must be replaceable ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 8310
If it is the ram proper that's leaking then I believe it's goodnight Vienna but do check the leakage return collar, as indicated by the red arrow in the picture below:
If that one is perished or split then it can be replacved using the XM component under part no. 95 640 212.
If it is the collar that's failed there will be relatively little LHM in the plastic bag. However, if the plastic bag is full then sadly it is the ram itself that's gone, most likely due to a scored/damaged piston rod.
It may be worth a chat with Pleiades to determine the repairability of a ram.
HDI
- x 7
Many thanks for that Jim, most helpful
Looking at that pic it could be the leak return collar, fingers crossed !
I'll be able to check for certain on Tuesday when I can get the car back on the ramp.
Do you know if the ram can be replaced with the rack in situ ? Just in case it is the ram !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 8310
I can't say for sure but I reckon it can. I once swapped a 405 ram in-situ without much difficulty and the overall setup is pretty much identical. It's be a bit fiddly...HDI wrote: Do you know if the ram can be replaced with the rack in situ ? Just in case it is the ram !
You may need to make up a custom flare-nut spanner for the hydraulic unions as space might be a bit tight to swing a full-length one. On the 405 I needed to chop one in half...
Fingers crossed it's the collar that's bid a fond farewell and not the ram itself...
rory_perrett
addo
- Sara Watson's Stalker
- x 95
- x 8310
addo
- x 95
What I and others need, isn't (AFAIK) specifically sold.
For the Xantia return "trees" I need like a plug cutter to clean the last bits of old hose from the factory pressed-together union. In the past, using a small right angled die-grinder with drill chuck and shortened 1mm bit (a little like dentistry!) has worked.
But I reckon on wimping out, and making new trees from metal with bubble flared ends and using hose clamps...
Or we go to one of the "made to order" plastic places in Thailand or Vietnam, and get new unions moulded off some originals (and what about heater hose elbows while we're at it?).
A leakback fitting and new strap for my nearside strut is three days away, and just over £47. Some things about Australia are less good!
KennyW
- x 164
HDI,
The only question is are they same ram between 1.9TD and HDi
Kenny
I have a couple of spare rams in the garage.HDI wrote:Yup, it's the plastic bag section !
Kenny
C3 1.4 petrol (SWMBO)
rory_perrett
HDI
- x 7
I also think they are the same, could anyone confirm please ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 1484
addo
- x 95
