C5 1.6 Hdi Steering wheel angle sensor
mooseshaver
Unread post by mooseshaver »
Another fault my Lexia showed me was wrong or no parameters? fromt he steering wheel angle sensor.
Is there some way a compelte muppet with a Lexia can recalibrate the sensor?
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
x 1908
It's there somewhere - I managed it!
Not that that's much help in exactly where. I just poked around the menus until I fell over it. It was a Phase 1 though, I can't see the Ph I being so completely different.
cachaciero
x 9
Re: C5 1.6 Hdi Steering wheel angle sensor
Unread post by cachaciero »
mooseshaver wrote:Another fault my Lexia showed me was wrong or no parameters? fromt he steering wheel angle sensor.
It should be under ABS/ECP menu as I remember, assuming that the 1.6 has ECP if it hasn't then no calibration is required at least on an S1
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
citrokid
Unread post by citrokid »
what does this error mean and is a recalibratuion the solu.tion
Citroenmad
x 110
Unread post by Citroenmad »
I thought id odd that mine came up with this fault too, as its not a hydractive plus. Though as mine doesnt have ESP i cant imagine it has any effect on the car, ive put it down to me changing the Comms unit without coding. Might cause problems with cars with ESP though.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
mooseshaver
Not had a chance to have another go with it. I believe my VTR has ESP, but there are no warnings saying its been disabled.
The steering wheel is wonky. Driving straight on the wheel causes car to drive at an angle. That might be related?
Gone cars.
Citroenmad
x 110
I wonder if your car has had the Comms replaced at some point? Its a possibility i guess, as that would explain your wonky steering wheel too, as it has to be removed. Though that could be down to tracking or a number of things.
03 Seat Arosa 1.0S
cachaciero
x 9
mooseshaver wrote:Not had a chance to have another go with it. I believe my VTR has ESP, but there are no warnings saying its been disabled.
The car drives at and angle to the steering wheel because at some point somebody has done the tracking on one side only.
This does mean that it's likely that the sensor will agree with the wheel which in turns means that when driving straight it will have an offset.
Get the tracking done with the wheel clamped in the straight ahead position then worry about the sensor.
On the S1 sensor calibration at straight is -127 degrees or +52 deg there is no hysteresis straight ahead can be either. I have to say I think it's a bit strange but that's the way it is, on mine at least, if this is wrong I would like to know.
It is probably not so strange, on S1 non ESP equipped cars there is a steering sensor but as far as I know it is only a left / right switch which goes into the BSI and as far as I know the only thing which looks at it is the autobox when fitted.
For cars fitted with ESP the sensor is connected to the ESP ECU via CAN bus and as well as position it also gives angular velocity.
I guess S2 cars being all CAN bus have the same sensor even if they don't have ESP and if they don't have an autobox either I can't see that it does anything for anything.
Both the Autobox and ESP are only interested that there is a deviation from straight, the autobox doesn't care if it's left or right it only uses the signal to suspend any gear change that may have been pending. The ESP needs to know if it's left or right after that it's only interested in how quick the wheel is moving, at least that's my understanding.
The ESP "knows" that the sensor has been calibrated BUT it has no real way of knowing that the calibration is not accurate so the ESP will not fail with a badly calibrated sensor, again thats as I understand it :-)
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
mooseshaver
The steering was perfect when I got it.
Then there was a winter pot hole.
The main Dealer has agreed to look at he faults and report them to my warrenty company in an attempt to get them fixed under the warrenty.
I bought the car far away, and garages around here generaly don't want to deal with the warrenty, even if I pay and get reimbursed by the warrenty.
Gone cars.
RKM
Unread post by RKM »
For various reasons, including having the tyre pressure monitors replaced, I had my 56 plate C5 Exclusive being worked on at Citroen UK's HQ and I spoke to several senior technicians there. My car had the steering angle fault recorded in lexia, which they cleared. I was told that this was a common "ghost" fault and they did it when they were new. It is a strange quirk and does not affect how the system works
R
