C5 estate tailgate springs
Julz
Is it possible to adjust the spring tension on the rear tailgate or do they have gas struts somewhere? Mine have become very lazy since it's got colder outside.
mooseshaver
Don't have an answer, but both my C5 Estates, and friends Pic also do this every year when the weather is cold, so you are not alone.
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
VertVega
- x 13
- x 1506
C5 estate appears to use a gas strut fitted inside the roof behind the hinge (there are two - one for the glass and one for the main part). God only knows how you replace it - remove the head lining???
In any case, Citroen want nearly a ton each for the main ones (8731F4), glass ones are 'only' half that (8731F7), so I'd just have a piece of wood in the car to hold the door up!
cachaciero
- x 9
RichardW wrote: In any case, Citroën want nearly a ton each for the main ones (8731F4), glass ones are 'only' half that (8731F7), so I'd just have a piece of wood in the car to hold the door up!
Go and look at www.strutsdirect.co.uk/ I am sure that they will have a solution somewhat cheaper than Citroens prices.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Julz
unfortunately not got my struts, found another site www.sgs-engineering.comcachaciero wrote:
Go and look at www.strutsdirect.co.uk/ I am sure that they will have a solution somewhat cheaper than Citroëns prices.
cachaciero
that has the glass ones but not the main ones at £12.99
addo
- Sara Watson's Stalker
- x 95
Julz
Had a reply from www.sgs-engineering.com
Just need to work out how to get them out without wrecking the head liningUnfortunately we cannot supply new struts for the whole tailgate. The spring around the outside of the strut is unique to the C5 and we do not supply an equivalent. We may however be able to re-gas your original struts depending on their condition.
A re-gas is £25.03 delivered for the pair (£7.50 per strut plus £6.30 carriage and VAT) and struts are usually turned around within three working days.
Philjw
tmead
- x 11
Pleiades
Tailgate struts...
Now you all know that I do not want to use this forum for blatent advertising, but I can re-gas tailgate struts for most cars.
The first sign of the struts loosing pressure is that they only hold up on sunny days, ie the heat makes the gas expand and the pressure goes up a little, when they get cold the pressure drops and the boot lid smacks you on the bonce hence reminding you to get them sorted.
If you take the struts off and push them down they will still have a fair bit of resistance, even though they dont work properly, if you push them down on a set of bathroom scales, the point that they start to move is telling you in KG, how much force they still have left. A strut that has the mark 480 nm on the side, should move at about 48kg.
If there is no pressure at all in the strut, ie, the strut collapses down and does not come back out on it's own, then the chances are that the seal in the strut has failed and the strut although will take a charge, will not last.
Run your fingers down the shaft of the strut, If you find any rough bits or rust pits, then these will have torn the seal, again making the strut useless.
As said, we can re-gas struts and have been doing since the days of the GS but you would have to send yours in to be done as we do not carry core units.
Regards
Martin.
Regards
Martin.
tmead
- x 11
