xantia key code pad
garry
xantia key code pad
hi,i have a 98 1.8 16v xantia which has been of the road for a couple of years without a battery on,i have just put the battery back on but it won`t accept the code,any ideas thanks garry
citroenxm
- Fallen Hero
- x 70
messerschmitt owner
spider
- x 77
They should not lose the code, I've never heard of one doing that, although it is in theory possible as I guess its a tiny eeprom in a way.
Is it actually working properly though with regards to how the lights are responding on it ?
Ignition off + doors locked etc = red light flashing
Ignition on = red light on, type code, green light. Listen for bleep when pressing each number. Faulty keypad membranes rare but not unknown.
If you have both lights on at the same time or any other oddities its likely you have a wiring issue (engine bay multiplugs maybe corroded a bit) , or if the keypad is on a 'flap' like the 406, the wiring can break on the hinge (not difficult to fix but a bit fiddly)
Andy.
- x 8468
My XMs
