I've been offered a 1993 Citroen Xantia 1.9td as my friend wants rid of it.
Just wondered if anyone could give me some advice on weather its worth doing up.
It's not perfect by any means, its done 175k and could really do with a new cambelt as it's 'unknown' when it was last changed.
It smokes a bit when started first thing in the morning but its fine after that (not really worried about that - its an old diesel!)
There is a knocking noise coming from the gearbox and the gearstick shakes when you put your foot down, any idea's on what that could be?Once up to speed it drives great.
I've never owned a car with such high miles, although have seen 1.9td's with over 200k so I guess they must go on.
I've heard these engines can suffer with head gasket problems, any advice on how to prevent that from happening?
Lastly the suspension seems nice and smooth and front spheres and acc sphere has been recently changed, plus it has had new glow plugs, fuel filter, rear arm bearings and clutch clip all in the last 6 months.
Thanks.
1993 xantia 1.9td - a good buy?
- x 8358
Yes, a very good buy
A 1993 model will be a "sinker" and will sink down to its bumpstops overnight whereas the later anti-sink Xantias won't. It suffers not a jot from being a "Sinker" and in many ways, it benefits. Spheres last longer for one thing.
You'll find, I hope, the Cheverons are on the bonnet rather than the grille.
All the major work has been done
The banging will be caused by the lower engine mount donut having gone soft. It's a bit of a task to replace it but not beyond the pale.
Smoking in the morning will be either weak glowplugs or perished leakoff pipes. neither is a showstopper. What colour is the smoke?
175K is a low mileage really. Just run in.
Go for it! One thing about the early Sinkers as they are nowhere near as complex as a later Xantia. In reality, they're a BX wearing a pretty frock...
red_dwarfers
- x 58
Get it before one of us find out where its too!
A very good find that one, first model year sinker/chevrons on the bonnet with a 1.9 TurboD engine I guess? They were only around for a few months as the majority of sinkers were petrol.
As long as its been looked after to a degree there's not really much that can go wrong. Do check the front strut top mounts for excessive rusting as thats the only slightly expensive bit (£130) if they need changing.
I know little about gearboxes but no doubt someone will be along soon to point you in the right direction.
At the end of the day, if you have the facilities to do at least some of the labour yourself Xantias are cheap cars to run.
EDIT: What did I tell you? He got in there a second before me!
Kev
'19 C4 Cactus 130 Flair
KevMayer
It seems like the previous owner has looked after it.
How much does he want for it? As long as he doesn't want silly money (£500 plus say) then it appears to be a good motor.
As long as there's no bodywork rust then these Xantias can go on forever.
Have you any photos you can post?
Cheers, Kev
colski
Ok, seems to be all positive so far. Yes its a sinker and has chevrons on the bonnet and no airbag.
The bodywork is totally rust free and looks good underneath too.
Thank you CitroJim on the info about the knocking noise with the gearbox, thats really helpful
I will try to upload some pictures if I can work out how!
- x 5671
Nice find and well worth putting a little bit of work into.
Push the email button at the foot of the post.
As far as the strut tops are concerned, take a look in this thread, with particular regard to andmcit's latest post.
There is a guide here but for a quick fix email them to me.colski wrote: I will try to upload some pictures if I can work out how!
the_weaver
Smoking on startup, in the morning, could be an air leak into the fuel system. I would check the fuel pipes for fuel leaking out. Start at the priming bulb and follow the pipe in both directions. Check the priming bulb for splits. You might want to try squeezing the bulb a few times, in the morning, before starting, to see if the smoke is reduced.
It could also be due to a failed glowplug. I know they're new but what make was fitted? The TD's are tough on glowplugs and some aftermarket plugs aren't up to the job and will fail quickly. The best make is Beru, which last a long time.
Paul
Paul
andmcit
- x 30
It's not this one is it?
http://cgi.ebay.co.uk/citroen-xantia-red-/110602902157
it's a L reg and even says low mileage!! Doesn't say if it's a 16v or a TD
mind although most Xantiae are TD...
Andrew
Andrew
jgra1
- (Donor 2021)
- x 36
citroenxm
- Fallen Hero
- x 70
As I keep reminding people, Chevrons on the bonnet and NO air bag, does not always mean a sinker...
You need to listen to the car running, does it HISSSSSSSSSSS a lot when running??
My Xantia with chevrons on bonnet and no air bag IS an Anti Sinker! Yet ive customers with an identical Registered year and looks, and she is a Sinker!
The other easy way to tell, is there a sphere in the middle just forward of the spare wheel carrier?? If so its an anti sinker... also, the Hydraulic pump will have ONE metal Pipe and ONE larger rubber feed pipe, below the altinator..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
colski
Thanks Paul (the weaver), some useful advice there. I'm not sure what make the glowplugs are, but no doubt they will have some heavy use this winter so time will tell.
No it's not that one Andrew, i'm buying it off a friend who no longer wants it, and it's silver!
Thank you John it's good to have as much infomation of different possibilities on what it could be. Forgot to mention the needle for the speedo wobbles when going up the gears too, but again its fine once in forth and fifth, don't know if that is related to the problem aswell or if its just how they are - its an old car!
Lastly to Paul (citroenxm) its a sinker! My friend has owned the car for a while and it sinks right down after an hour or so, and yes it does HISSSSSSSSS alot when running. It's quite an early one being registered in august 1993.
- x 8358
colski
citroenxm
- Fallen Hero
- x 70
DEFENATLY!
Nice one! Nice too hear of another Sinker... Ive been told when customers get rid of their L reg sinker, I have first refusal...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
colski
