Xantia HDi diesel filter
- x 1507
How many pipes can one filter need??? There are about 8 on the filter on mine...and it is leaking somewhere. Not sure if it is the filter body or one of the pipes. How do they come off - press in the little coloured tab and the pull the pipe off? Have not changed the filter since I have had the car (ahem 60k miles....
) so was thinking maybe as a first step I'd just fit a new complete filter housing and see if that fixes it (I also have the rattly noise at switch on which that should help with too).
carpysmith
hi richard,
changed fuel filter on my xantia hdi a coupla weeks back, only had 2 or maybe 3 pipes on it (cant remember without goin outside and checking) you do indeed press coloured tab and just pull pipe off (piece of cake!!)
top comes off by turning the top quarter of a turn (anti clockwise i fink) using spanner or socket on hexagonal bit on top.
there is an o,ring and springy washer under lid (maybe leaking from there?) mines a bosch filter housing by the way.
hope that helps!!
regards steve (aka carpysmith)
1999 xantia 2.0 hdi sx estate
hope that helps!!
spider
- x 77
From memory there seems to be two types.
As above pipes just come off press clip in and remove them carefully.
The type with the electric plug on, I found easier to remove the couple of 10mm bolts and take the whole housing off to change the filter, the earlier one you can just turn the lid in situ.
Change seals on lid etc you get with the new filter, to avoid leaks. There is a springy washer in the lid yes.
Push pipes back on and you will hear them click. Attempt to gently pull them off to confirm they are securely attached.
If you do not have a pump primer bulb when you have finished:
Switch ignition on, do not attempt to start. Wait about 5 seconds then turn ignition off, wait about 10 seconds, then repeat this about 3 or 4 times to 'prime' filter.
If you have a primer bulb, simply squeeze that a few times instead.
Andy.
- x 1507
Cheers, was releasing the pipes I wasn't sure about. There appear to be 5 pipes on the filter - feed, 2 feeds onto the pump from the top, and a flow and return to the thermostat housing. Have ordered a new filter housing complete from GSF so hope that will fix it. If not, then the pipes are only about £10 each, so if one has to be replaced then not too bad. Although, getting to the other end of the ones at the thermostat housing looks
Mine is Bosch with the in tank pump - I can hear it priming no problem....
DHallworth
- x 173
They can sometimes be a sod to get off.
One of the spiggots that the pipes go onto broke on my brothers HDi fuel filter housing.
My 406 failed it's MOT on a Diesel leak last week, if you remove the drain screw from the bottom of the housing, there's an O ring on it, a new O ring solved my leak and it sailed it's retest the next morning.
David.
David.
'98 Xantia Activa V6
'13 Renault Zoe - Broken
'15 C4 BlueHDi Feel - For Sale
Citroenmad
- x 110
There are lots of pipes going to my HDis filter, ive changed a few now without any problems - the filter not the housing. I changed mine about 6 months ago, but recently it developed fuel leak, i nipped up the filter housing which stopped the leak, i can't have had it tight enough, though it did last until now.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1507
Job done this afternoon - not too bad, but filthy horrible as diesel filters usually are! Looks to have cured the leak, will see when it's been for a run. Might have been the drain spigot, but the O rig looks intact. Old filter looks pretty manky, but then it has been on for >60k miles....! The design is p**s poor really, with the 'sump' on the clean side, so all the rubbish falls into it when you take the filter element out, and you're relying on the seal at the bottom and top the keep the rubbish out.
