V6 Oil filter
Toby_HDi
x 3
V6 Oil filter
Unread post by Toby_HDi »
Quick question regarding filters for the ES9J4S engine.
Am I being completely stupid or will a different size filter have a negative effect?
I have a filter that is the same diameter as the OEM one but it is about 4cm taller. Same thread size and by-pass valve pressure.
EDIT: Ignore me. The one I supposedly need is about 1cm smaller than OEM. Getting my mm and cm mixed up. The taller filter doesn't have the same by-pass pressure either.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
spider
x 77
Unread post by spider »
Perhaps the V6 filters changed when the others changed in 98 to the longer service intervals.
For Peugeots, the XUD and TU's changed from 1109N2 to 1109T0 (although the Citroen number will be different, and the V6 one will be different) , you know what I mean, just suggesting perhaps the filters changed when the service intervals were 'stretched' ;)
Andy.
dnsey
x 19
Unread post by dnsey »
Maybe you should contact Rmunns, who apparently has a batch of V6 filters (see his thread below), which are not ideal for his car. I don't know if they'd be right for yours though, or if he'd be interested in coming to an arrangement!
rmunns
x 9
Unread post by rmunns »
I am going to sell them.
See relevant forum section.
lexi
x 133
Unread post by lexi »
I am using the same filter that is used for 1.9 td. Two reasons:
I have a good few of them and one of the French parts suppliers lists it as being suitable. I think the real McCoy is a slightly longer and higher volume version.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8408
lexi wrote:I am using the same filter that is used for 1.9 td. Two reasons:
They certainly fit but they are considerably smaller. I worry that some factors list them for the V6... Personally, I'd not use them.
I use the Mahle OC503 and this is a considerably bigger filter but not as big as some, notably Mann, that I've seen.
Mr. Munns, I'm interested in a few of your surplus ones. No rush and I can wait until you are in the UK.
