i have just had someone ask me what is the cause of his C5 speedo reading about 8 to 9 MPH under what its realy doing,
he has found by driveing through speed camera's at 30MPH they flash, but if he stays below 21MPH they dont,
i have not seen the car yet and dont know exactly what modle it is, i think he say its a 2.0lt diesel,
regards malcolm
C5 speedo
Clogzz
- x 40
- x 5672
Thought of that Cloggz but thought it unlikely to make such a difference
I find that mine, as with most, reads high (but note that some speed indicator signs read low and will flash up 30+ when you are only doing 28.
My guess - somewhat overshadowed by Cloggz info, would be the speed sensor - which is part of the ABS system.
- x 1938
Put it on a Lexia and check that the correct size tyres have been ebtered.
Citroenmad
- x 110
I find the C5s to be very accurate. Our C5 SX is spot on, when i had larger wheels on from a C5 estate it was underreading by mph what i was actually doing. If i was going by the speedo doing 70 id really be doing 72.
Apparanty C5s can be set by a lexia to tell them what size wheels they are wearing?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
bencowell
jimleshed
Surely if it was a sensor (ABS for example) that would mean that would be out by 2/3rds ish of the whole speed range...so at 60mph it would show 40 (and when showing 60 you'd be doing 90) I think you may realise that something is seriously wrong. The same would be true for the wrong size tyres - either actually wrong or entered wrong in setup.
I could be wrong though...Tyres would need to be approx half as big again as they should be (eg 24" fitted instead of 16").........
But, if its out by a consistant 9mph (and I guess the needle is not moving until you have a good bit of speed on?) its got to be something else.
Needle in the wrong place sounds good to me! or something more complex and confusing...
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
jimleshed
Another thought.
If its out by 2/3rds over the range rather than just consistently 9mph, could it be a conversion error between MPH and Km?
19MPH = 30KmH (ish)
Can this be set anywhere? I think the speedo has dual speeds marked, but is there a KMH/MPH setting that could alter needle position? (asking the various Guru's here...)
Actually, I am clutching at straws....we really need a bit more info!
19MPH = 30KmH (ish)
Jim Le Shed
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
bencowell
jimleshed
I know it doesnt, as I said that the dial was dual speed marked.
But, it doesn't stop the electronics having a conversion factor somewhere, for some reason best known to the French.
We still need more info from Citronut, if possible....
Jim Le Shed
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
- x 94
wright
if the motor on the speedo needle has been replaced, the needle was probably put back on wrong, a lexia help to calibrate, in the actuator tests it will put the needle to 4 different speeds, and you can adjust the needle until its at the correct point during an actuator test, i have done this on a few c5s
micky707
Re: C5 speedo
Hi all, I have just upgraded to a 56 plate C5 VTR, and after the xsara find it amazingly comfortable and am well chuffed. Bought it at Auction and it has 48000 miles on it. 2 things wrong, first thing was the boot lid opened everytime you blipped the fob, wd40 in the catch and job sorted. The speedo was under reading by 8 mph as checked with tom tom, i have taken the advice from this thread and popped off the cluster front and unclipped to get at the needle and moved it in line with the tacho at 0, job done, test driven and so far so good, i cant imagine what citroen would charge for something like this but only took 20 mins, tacked it with a minute amount of no nails so it doesnt slip down again. Thanks for all your advice as it would not have been something i would have attempted normally.
Micky
Micky
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
2 Pug 306's
Citroen ZX 1.9D
