I'll let you have go and you'll soon see what I mean, no vibration at all.Toby_HDi wrote:I have heard this, unfortunately I have never sampled a straight 6. I would like to though.DickieG wrote:V6's are great but for smoothness straight six is the way to go
Killing of the V6... anyone else sad?
DickieG
- Monaco's youngest playboy
- x 33
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
red_dwarfers
- x 58
- x 8409
And I can bear witness to an engine that is running but you are barely aware.DickieG wrote: I'll let you have go and you'll soon see what I mean, no vibration at all.
The 4-stroke straight six and the 2-stroke triple are naturally perfectly balanced engines with even firing intervals. Nothing is smoother*, except perhaps a V12 but then they're just two straight sixes lying side-by-side at the end of the day...
One of the most naturally unbalanced engines is a 4-stroke triple and a V6 is not much better, being two triples lying side-by-side. Special tricks are used in the V6, such as off-set crank pins, to make them acceptably smooth.
*Piston engine-wise. A Wankel is very smooth but it does not have pistons in the accepted sense.
addo
- Sara Watson's Stalker
- x 95
Sid_the_Squid
According to Wiki a V8 has no better inherent balance than a straight 4 which as we know is not a fully balanced engine, certainly not as balanced as a straight 6 or a V12.
Keeping on topic, I also shed a tear at the demise of large engine car.
Source
http://en.wikipedia.org/wiki/Engine_bal ... _cylinders
Source
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
addo
- x 95
evilally
- x 3
What also contributes to an engine's "smoothness" is the number of power strokes per crank rotation. A cylinder in a 4 stroke engine only produces 1 power stroke in 4 (average 0.5 power strokes per crank rotation). A straight 4 is producing 2 useful power strokes per crank rotation, whereas a V8 is producing twice that much. A rotor in a rotary engine is producing 3 power strokes per rotation which helps it deliver it power very smoothly.
'96 405 1.6 GLX with 306 GTI engine on Cat cams @ 195bhp
'05 RenaultSport Clio 182 Cup, 102k
'97 406 1.9TD, 314k.
- x 8409
Indeed yes and with them come a big disadvantage.addo wrote: From memory the counterweights of the V-8 were a large part in its overall smoothness.
On V8s, there was something about flat-plane cranks and vibration as well. I can't recall now if a flat-plane one is better or worse than a twisted one and for what reasons but I do believe they cause more vibration but deliver better response as they can be much lighter. Those heavy counterweights in a V8 with a twisted plane crank really dent the ability of the engine to rev quickly and respond to the throttle and maintain acceptable smoothness.
The ES9 60degree V6 crank has practically no counterweighting at all according to the diagrams. Balance is achieved with the offset crank pins to achieve even firing. Its throttle response pays homage to that!!!
There is a lot more to engine balance than just the number of power strokes par-se. They need to be evenly spaced and close together. An I4 have them 180 degrees apart whereas a straight 6 has them 120 degrees apart.
That's by no means the end of it either. Smoothness of engines is a deep science and whole books have been written about it. When you get down to analysing rocking couples you're in deep
Vee engines naturally end up with uneven firing angles and the harshness is worse as the Vee angle gets more acute, hence why a boxer is smooth as it's effectively a 180 degree Vee. A Vee is not a terribly smooth engine fundamentally but has the huge advantage of packing a lot of cubes and cylinders into a small space. The uneven firing angles is what gives Vee engines their characteristic burbly exhaust. Early Vee-twin motorbike engines were a problem and needed special magnetos to generate uneven sparks for them. Until those magnetos came about even firing magnetos were used and set at a compromise.
Vee-twin motorbikes are horrible to this day. They sound gorgeous but they're like riding a road drill. Harleys especially. How the yanks can ride them interstate is beyond me. Riding one for about a mile was enough for me...
The old PRV V6 was a 90 degree engine (actually a V8 with two cylinders lopped off) and it used a balance shaft running above the front bank cam to achieve silky smoothness. In the 60 degree ES9 the crankpins are offset relative to each other to make the engine an even firing one and thus be able to dispense with a balance shaft. The ES9 crank is quite a work of art, its construction includes flying buttresses!
lexi
- x 133
I've had 2 straight sixes. 71 k reg 2.5pi Triumph and Patrol 4.2 diesel Lovely engines.
Patrol had some beat when you put your ear to the snorkel
V engines are compact........luv em.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8409
