Hi all,
the van needs a few things doing to it (filter changes, fluids renewing, that kind of thing) but under the bonnet is filthy, and I'm just wondering what the best way of cleaning all those nooks and crannies is so as to avoid contamination whilst carrying out servicing.
cheers,
Cleaning under the bonnet
addo
- Sara Watson's Stalker
- x 95
Can you get a pump spray bottle from Wurth (the bottle with solvent proof seals, not the degreaser pump bottle), and a litre of brake cleaner? Lay old newspaper underneath while you do this, and avoid risk of fire - brake cleaner is quite flammable.
Brake cleaner will remove the loose soot and oil/grease while evaporating fast. Afterwards, you might use regular water-soluble degreaser - but be sure to (a.) wash it off fully and (b.) keep it out of spark plug wells, distributor caps, alternator bodies etc.
red_dwarfers
- x 58
red_dwarfers
- x 58
Jimothy
- x 5612
evilally
- x 3
I've used Autoglym Machine Cleaner in the past with good results. Cover any electrical items, alternator etc with a plastic bag. Work in a small area at a time. Apply machine cleaner liberally and leave it to soak for a few minutes. Agitate with the brush and then rinse with the skooshy bottle. It's also safe to use on all materials under the bonnet.
'96 405 1.6 GLX with 306 GTI engine on Cat cams @ 195bhp
'05 RenaultSport Clio 182 Cup, 102k
'97 406 1.9TD, 314k.
vince
- x 13
Jim, short of buying anything fancy for the task...get 2 rags...one wet and one dry. scrub with the wet one and then dry with the dry one. Once youve got round everywhere then clean up the plastics with
£2.50 tyre shine from Tesco and your done
Wont be mint but will be alot cleaner
Brigsygtt
