DEBUG MODE
Forum News, Announcements and any issues you're having with the forum
Trainman
(Donor 2018)
x 43
DEBUG MODE
Unread post by Trainman »
phpBB : Critical Error
Error creating new session
DEBUG MODE
SQL Error : 1062 Duplicate entry '9227' for key 2
INSERT INTO phpbb_sessions (session_id, session_user_id, session_start, session_time, session_ip, session_page, session_logged_in, session_admin) VALUES ('edc71f27265406935a4c4cfc44bc22cc', 9227, 1285232351, 1285232351, '3e194837', 3, 1, 0)
Line : 187
File : sessions.php
The above is what greeted me about 5 minutes ago when I tried to log in.
Steve
http://c6owners.org/index.php
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Me too, but seems solved now...
PAul
A very sad...
1994 XM 2.1 d auto
Xaccers
x 188
Unread post by Xaccers »
Session table had crashed, I've repaired it with washing up liquid bottles and some sticky backed plastic :)
DIY sphere tool
Trainman
(Donor 2018)
x 43
Xac wrote:Session table had crashed, I've repaired it with washing up liquid bottles and some sticky backed plastic :)
Ah, only a temporary fix then, should have used double sided sticky tape and PVA glue, Blue Peter badge technology :lol: :lol: :lol:
Steve
spider
x 77
Unread post by spider »
/Tech type post
Suggestion: consider moving the session table to memory to prevent crashes.
It will retain the table structure on disk obviously, but the data contents are held in memory. These will be lost when server offline (but mysql offline = no forum anyway)
They tend to not crash (at least in my experience with other software) when set to heap. ;) , I doubt there is any data held in the session table that is needed after a restart (although I'd have to install phpbb2 to double check they have not held any critical data in it, I doubt it though)
Does cause a small increase in server memory usage though, but seems an acceptable compromise in most cases, as a memory based table cannot crash and given its nature it is the most heavily used table. :)
Caution ( ! ) don't set any other tables to memory, I've seen that done.
/End of tech type post
Andy.
davetherave
x 4
Unread post by davetherave »
I just heard a wooshing noise above my head..... :lol:
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
that was the table before it crashed into the wall :D
Xaccers
x 188
Cheers Spider, have now changed to HEAP
DIY sphere tool
spider
x 77
Xac wrote:Cheers Spider, have now changed to HEAP
All being well, it should never crash now (that table anyway)
I can't (without installing and checking) seeing anything of value living in that table really, obviously server restart = loss sessions so everyone will have to login again but that should be it really.
You're welcome anyway :)
Andy.
Xaccers
x 188
It crashed due to the server going down without giving sql enough time to shut down cleanly.
It only contains temporary session data.
Will keep an eye on memory use, if it does start going up a significant amount (I really doubt it) I've got a script that can clear out the oldest sessions.
DIY sphere tool
x 5679
Re: DEBUG MODE
Trainman wrote:phpBB : Critical Error
DEBUG MODE
Line : 187
File : sessions.php
I got the same thing yesterday evening and thought that it was just me.
spider
x 77
Spoke to (well messaged) Xac earlier, should hopefully not happen again now ;) , all being well that is. :)
Andy.
