Deaf and Dumb Xantia
Deanxm
- x 87
The cat will not affect the running of the car so long as its not blocked becasue it is downstream of the Lambda sensor, the cat can be removed and nothing will happen....................well you get more power and better economy, but othher than that nothing
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 5672
Won't the sensors detect no difference before and after the cat and the ECU conclude that the cat is non-functional?Deanxm wrote:The cat will not affect the running of the car so long as its not blocked becasue it is downstream of the Lambda sensor, the cat can be removed and nothing will happen....................well you get more power and better economy, but othher than that nothing![]()
D
DickieG
- Monaco's youngest playboy
- x 33
Not on Xantia's as they are not EOBD2 compliant, i.e. they only have one Lamda sensor, EOBD2 car's have a Lambda sensor pre and post cat.myglaren wrote:Won't the sensors detect no difference before and after the cat and the ECU conclude that the cat is non-functional?Deanxm wrote:The cat will not affect the running of the car so long as its not blocked becasue it is downstream of the Lambda sensor, the cat can be removed and nothing will happen....................well you get more power and better economy, but othher than that nothing![]()
D
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 5672
Deanxm
- x 87
It may fail the emmisions test come mot time, although mine didnt with the cat missing, unfortunatly when they noticed the car had to have a cat by law they failed it for having no cat
D
D
XM Prestige PRV6 92
tim leech
- x 12
DickieG
- x 33
- x 8417
tim leech
- x 12
Hmm well maybe I spoke to soon, seems to be running better and a bit more responsive, overheated on the way home a bit, airlock it seemed, gone now and keeping nice and cool. Quite lumpy though and has cut out a few times which it didnt do before. Whilst on the gas tester the co2 did go down to 0.0!
Will get some new plugs etc and give it a good run.
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
