how to lower the front suspension of a xantia '93 model
argopanos
hi again from greece.my problem now is that the front suspensio has raised adout 3cm after i got the balls changed in a garage.how can i lower it manualy ,there is some bolts but i dont know witch one and how. Lhm its ok
- x 94
DO NOT ADJUST ANYTHING untill
you have checked and free off the hight corector linkage's/mechanisum as they become seized, then they stop the car rideing/settling at the correct hight,
the LHM has no bearing on susspension to high, although if the LHM was to low it can stop the susspension comeing up to full hight,
regards malcolm
regards malcolm
Old-Guy
- x 29
An educated guess is that the garage is ignorant about Xantias and while replacing the ball joints, they have displaced or broken the white plastic link (the so-called 'dogbone') between the height control valve mechanism and the anti-roll bar.
You could take it back and complain, but they will probably make matters worse.
Brief instructions and pictures HERE
- x 94
Old-Guy
- x 29
Oh dear, another spheres-up!
But the diagrams should still help Argopanos.
Guy
Guy
argopanos
