Xantia Multichanger and CD-R's
MikeT
- x 232
Has anyone made their own CD's to play in the car via the standard CD multichanger player in the boot?
I made a CD from my MP3 collection (converted by Nero) not sure if it would work but was pleased to realise it does.
However, I get a lot of skipping, most noticeable when going over bumps so I'm curious to know if anyone else has tried this and how did it play?
davetherave
- x 4
Sl4yer
I've never had any problems with CDRs. However, my multichanger does skip quite a lot (not just on CDRs), especially over some of the potholes we have to put up with nowadays. I think a lens clean might be in order!
Burning at a slower speed may help though.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
Toby_HDi
- x 3
Mike,
They do work, as you have found they need to be in Audio-CD format - won't work in MP3 unfortunately.
I burn mine at the lowest speed possible and don't use cheap CDs.
Have never had a problem with skipping except for the odd one when going over harsh bumps and potholes.
This applies to the changer in the Activa and the one in the Coupe.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
Xaccers
- x 188
If you don't have Nero, and are running windows, import your mp3's etc into the Windows Media player library, create a playlist of the music you want to burn to CDs and burn the playlist.
WMP will automatically ask for the next blank CD when it fills one.
DIY sphere tool
DIY sphere tool
MikeT
- x 232
I'm using PHILIPS CD-R's. Retail CD's play fine without any skipping whatsoever so I'm leaning towards the discs being the culprit - something to do with the dye used perhaps but will try burning at the slowest speed too.
Can anyone recommend a good brand for CD-Audio format? I've seen discs sold specifically for Audio which could be a marketing bluff, I suppose.
- x 5688
Xaccers
- x 188
I use cheapo Tesco brand ones and have no skipping (unless I turn left hard and something heavy hits the changer!)
DIY sphere tool
DIY sphere tool
pug_owner2002
- x 3
In the cd players/changers I've had over the years I have had skipping, this has been using a variety of CDR's.
I sorted it by burning at the slowest speed possible (as Toby and others have mentioned), this cured the problem.
It may also be worth running a cd lens cleaner in the changer if it hasn't been done for a while.
Simon.
Simon.
R Reg Phase 2 306 DTurbo (Blaze Yellow) (Sold)
X Reg Phase 3 306 1.4 LX (Sold)
03 Renault Scenic Dynamique +
03 Seat Leon 1.9 TDi
52 Nissan Almera 1.8 sport+
Sid_the_Squid
All my car cd are cdr's. I don't have any skipping except on the old scratched CDs, I use memorex cdr's usually I used to be a big fan of the old memorex tapes.
I find burning at 16 speeds ok, sometimes one car get away with 32 speed, but the slower the safer really.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
MikeT
- x 232
Thanks, I burnt my second one at the slowest 12x and the skipping was greatly reduced (but still present over large enough potholes etc). Original music CD's, despite being old and worn have never skipped that I recall.
I'll try a lens clean next.
jgra1
- (Donor 2021)
- x 36
Mike I put an MP40 headunit from Sony in my xant, about £40 from ebay, (it's blue led's and not in keeping but.._) it plays MP3 Cd's fine, so that's 150-200 songs? on one cd and no skipping.. there is also I think a CDX50 or something that will go in there.. add the cost of a remote control (steering buttons) connector and job is good
Series 2 xant..
I am going to add a 6 disc MP3 changer to the coupe this weekend, which will work from the Clarion headunit - also Sony.. so that should = 6 MP3 cds in the boot
Series 2 xant..
- x 8456
Listen to Radio 4
It never skips...
Back years ago I had a Rover Metro with a CD player and it would not play burned CDs at all except...
I got hold of some coloured CD-Rs and black ones, looking like Sony PlayStation 2 disks, worked a treat. Blue and red ones wouldn't..
My changers skip occasionally on CD-Rs but as stated, burn as slowly as possible and it'll be better.
It never skips...
dnsey
- x 19
Unfortunately, it's difficult to settle on a reliable brand of CD-R, as even the major brands regularly change supplier, and therefore dye technology. If you find some that work well, it's worth buying a good quantity fom the same batch.
In any case, it's becoming very clear that CD-R recordings are only temporary, and become unplayable within a few years - faster when kept under adverse conditions.
- x 8456
I've some audio CD-Rs that I burned about 8 years ago now and they are still fine. That was admittedly on good disks, back in the days when they were reassuringly expensive and the technology was quite new.
CD-Rs suffer a condition known as bit-rot!!!!
What does amaze me is that I still use a 25 year old Philips CD-160 player on my lounge stereo and that will play absolutely anything, despite being a very early example of a player; quite basic and designed before CD-Rs were even dreamed of.
It will even play damaged CDs that no other player will even deign to look at
I guess again that the age of the thing, it was built and designed properly for a very (then) nascent technology; it had something to prove at the time and it still is the best CD player I've ever known.
I note that some of my 25 year old CDs are a lot thicker, heavier and clearly made of better materials than modern ones. My copy of Pink Floyd's Dark Side of the Moon is at least 25 years old now and still as good as gold. That and Dvorák's From the New World were among the first two CDs I ever bought...
