citroen c5 hdi cam belt who can do it?
gazzas c5
Unread post by gazzas c5 »
Hi there,i have a citroen c5 hdi 2003 exclusive and need the cam belt changed on it,is there any one in the north east willing to do it cheap for me if i get the timing belt?many thanks let us know cheers
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
x 5672
When doing the belt get the water pump changed at the same time, also the tensioners if they are showing signs of wear, the DMF pulley too, along with the serpentine belt, tensioner and pulley too.
Increases the cost substantially but it is a lot cheaper than the results if these are neglected. Any of those components failing can be catastrophic - except the water pump - but they are guaranteed to fail 500 miles after the belt change.
If no-one steps forward, I had mine done here soon after buying the car.
Oldpug
x 94
Unread post by Oldpug »
No such thing as a cheep job when changing a cam belt.Find a workshop that will work up to a standard rather than down to a price.They would rather supply the parts, then the job is fully guaranteed.When customers supply parts what happens if there is a problem after?Have a look on www.goodgaragescheme.co.uk enter Citroen and your post code.
