Just managed to rip the fuel cooler of my xantia!! Didnt rise enough before setting off. Any advice for repairing and replacing?
Cheers
Xantia Fuel line
- x 8234
Fuel Cooler?
That's a new one on me Floyd
Can you describe the item a little better please..
Also, what model Xantia?
I know I'm suffering the effects of paint fumes right now but I cannot think of anything on the fuel system that is at risk of being damaged from driving off on low...
floyd
- x 8234
Xaccers
- x 186
KP had a similar issue by the looks of things
http://www.frenchcarforum.co.uk/forum/v ... 39&start=0
DIY sphere tool
DIY sphere tool
floyd
rory_perrett
Been there done that. Fortunately I was able to bend the fuel cooler pipe back without it breaking. It also smashed the connector on the plastic pipe from the tank to the cooler. This is the shorter pipe which was £8.82 in Oct 2008 from dealer. Fuel cooler (part no 1579 P2) listed at £68.22 inc VAT - or its a scrapyard hunt.
floyd
OnlineRichardW
- x 1465
Hmmm, I'd be working to stick the cooler back in..... Citroen fitted it for a reason after all! The HP pumps works hard, and the fuel is used to call this, in turn being cooled in the cooler. A new cooler is a lot cheaper than a new HP pump (or even a new LP pumps which is likely to be the first casualty of running hot). Mind you, running with at least 1/4 tank should help things, as there's more diesel to heat up in the first place!
spider
- x 77
Agree. It is there for a purpose. Have seen similar on HDi Pug 806's and 406's (probably other models too but not 100% sure)
Bit strange really, if you think of the older engines they spent a bit of time (usually half decent heating setup for the fuel) to get the fuel heated, and now with HDI's we are having fuel coolers, just shows how things change.
Andy.
OnlineRichardW
- x 1465
Homer
- x 16
There's one on my 807, you can see the air duct for it sticking down round about the front passenger seat area.spider wrote:Agree. It is there for a purpose. Have seen similar on HDi Pug 806's and 406's (probably other models too but not 100% sure)
I always assumed it was on the fuel return line to cool unused diesel before it went back into the tank.
