Today I learnt that the coolant temperature sensor could be causing my problem, I've tried disconnected it but it didnt do anything.
Continuity is fine back to the ECU and I am getting 5v at the connector end.
But I take it to really see if its not working is too just replace it?
A friend at work has a full diagnostics system on his laptop so hopefully sometime this week I will get to the bottom of this!!
Cheers all again for your help,
Shaun......
Loud Knocking Xantia 1.9td Lexia fault update - SUCCESS
MikeT
- x 232
The green sensor? You can put a multimeter across the terminals, set to 200K ohms, then run the engine up and watch the value progressively change (I think it's inverse to temperature).
My ECT sensor was faulty but on testing behaved itself just fine up to 60/70 odd degrees then it went haywire. £15 or less from main dealer, and all's well again.
Interestingly, the result of faulty coolant temperature readings meant the timing was being retarded unnecessarily. The differences weren't obvious when driving but the Lexia showed me exactly what was going wrong.
- x 8412
MikeT
- x 232
I'm afraid I didn't take notes and you know what my memory is like. But if it's like my failed sensor, that won't help because it gave normal readings from cold. Only when hot did it go crazy.CitroJim wrote:Mike, can you give Shaun a ballpark resistance for the Sensor, say at around ambient?
This is my thread on that issue.
http://www.frenchcarforum.co.uk/forum/v ... highlight=
shaunlfc1
Could mine be purely set to cold causing the ECU to just set the timing to advance?
What else would effect timing management, the car now has a new crank, injector sensor, I know the cold start solenoid thingy works, all wiring checks out using a continuity test. My colleague is hooking it up tomorrow to his diagnostics so all will be explained no doubt.
MikeT
- x 232
shaunlfc1
- x 8412
I don't think so Shaun, this pot (and it is just a normal three wire potentiometer) helps the ECU measure the lad the engine is under by comparing throttle angle with engine speed. If the load is high, signified by the throttle being wide open but engine revs are low it will do a timing trim.shaunlfc1 wrote:Would the load lever sensor be giving me the troubles I am experiencing, I've tried everything else, diagnostics been delayed til the weekend.
Cheers,
Shaun
Worth a check of course and it can be checked with an ohmmeter or by substitution, Just take care to ensure the relative alignment of pot to spindle is maintained.
I'm not able right now but tomorrow (remind me if I forget( I can run an ohmmeter across one I have here and give some ballpark readings and a test plan for it.
Maybe if the thing is completely open circuit it might make a difference. Also check that it's operating fork is not broken. It's made of brittle plastic and transmits spindle rotation to the pot. It's a tad fragile and gets more brittle over time.
shaunlfc1
Hi everyone,
Its been a while, and I've finally had the Xantia linked upto a Lexia.
The resulting fault and the only fault the Lexia showed was "Adjustment of Motion"
My money's on a problem with the timing? Is it possible the timing belt has jumped a tooth and not caused any major problems, apart from causing the horrible banging noise?
Finally a big thank you to Tony (cachaciero) for giving up some of his time to help me out this afternoon.
I look forward to seeing people's opinion on the fault I have.
Thanks,
Shaun
Thanks,
Shaun
- x 1240
shaunlfc1
- x 8412
shaunlfc1
Well I whacked in a new fuel filter the very evening the noise first happened, the old filter, was a bit discouloured but not that bad at all.
Is there any other problem with the fuel filter housing that could cause this problem?
How big of a job is to get the strainer out of the fuel tank to check?
Cheers,
Shaun
Cheers,
Shaun
MikeT
- x 232
