shell fuelsave diesel? anyone used this in a citroen diesel?
veralum
Unread post by veralum »
if so any difference? says can save up to a litre a tankful
x 5672
I will be filling up with it tomorrow, I don't expect there to be any difference, V-Power never seems to make a difference.
x 1240
Unread post by Peter.N. »
I have been running diesels for the last 30 years or more and have never noticed any difference between fuels.
Deanxm
x 87
Unread post by Deanxm »
saving "up to a litre per tankfull" seems like the sort of claim you make when your product doesnt do anything, pumping the tyres up[ a bit or using thinner oil, keeping the windows shut will all on their own do far more than that.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
rory_perrett
Unread post by rory_perrett »
Just running my first tank full. Have I noticed a difference? No. But I will continue to use it because the Shell garage I use is the cheapest. The 1 ltr per tank claim amounts to 2%, I'm currenly averaging 56mpg so that would be another 1mpg - we will have to see. V-power made no difference but then with the extra cost I didn't give it much of a chance.
Watch this space!
x 8395
Technically, it's hard to see how diesel can be made to give different results due to the chemistry of the stuff. Petrol yes, but diesel no. In a very modern one with sophisticated management perhaps but I'd not expect to see nay difference in a mechanically injected system or even a standard HDi.
On a related topic I filled my V6 up today for a run to Somerset tomorrow and accidentally filled it with BP Ultimate. I knew I would one day as they deliberately make the Ultimate nozzle look very plain so it looks like the ordinary stuff.
On a tankful of that I do expect to see a difference on a big petrol as it can run more advance but as there is no equivalent of an octane rating on a diesel (cetane is not the same at all) then it is hard to see what the management can adjust to enhance economy.
x 1488
I'm running it, but then the Shell garage is at the end of the road, and it is cheapest! Not had a full tank through yet, so no idea whether it's any different or not.
x 5672
I did that with the Accord.
That car was notorious for only ever doing 32MPG under any conditions and circumstances.
Except with BP Ultimate.
First tankful was a bit better, about 36 MPG, Next was much worse, about 25MPG.
Same run (to Whitby), same petrol station (Guisborough), same load in the car (me only) and all other variables exactly the same.
Never used that again.
Oddly enough, the C5 also does 32 MPG normally. Can be varied a bit but not by using different fuel types.
x 1240
What you encounter along the road will have a far greater effect on your fuel consumption, every time you slow down and accelerate you will use more fuel, a steady speed and light throttle will give best results, every time you stop and have to wait it knocks the consumption as does rapid acceleration.
Old-Guy
x 25
Unread post by Old-Guy »
As Peter N. says, what you encounter along the way will have a far greater effect than a small increase due to the fuel quality.
IMHO, the producer refinery can affect the fuel consumption on a diesel in a number of ways:
- by increasing the calorific value of the fuel to produce slightly more power for the same fuel burnt so less throttle is needed for a given speed/load/acceleration,
- by juggling the fuel chemistry so that the fuel burns more efficiently,
- or both.
I'm sure that Shell have conclusive test data to prove the advertising claim - otherwise Trading Standards would be down on them like a ton (sorry tonne) of bricks!
Like others, I buy Shell from our local garage because it's as cheap or cheaper than the Pace alternative and I've encountered the typical problems (and increased maintenance costs) from using 'supermarket' fuels.
x 5672
Peter.N. wrote:What you encounter along the road will have a far greater effect on your fuel consumption, every time you slow down and accelerate you will use more fuel, a steady speed and light throttle will give best results, every time you stop and have to wait it knocks the consumption as does rapid acceleration.
This is true and easily demonstrated with any normal car but did not apply in any significant degree with that Accord.
I drove it like a granny for the first few weeks until I discovered how to make the damned thing go.
Long trips, short trips. Stop-go, 100 mile cruise, drive at 50mph in textbook fuel-miser mode or boot the thing along at >120mph, all the same.
It may have been called Christine :evil:
amjake
Unread post by amjake »
I am now on my third tankful of diesel in two weeks!
I fill each week brim to brim do over 600 miles, first tankful the initial fill and tonight was my third tankful, by my reckoning Shell owe me 2 litres plus, why?
Results no change in consumption, still 44mpg and any noticable power/response difference? No!
Still happy to use the new Shell fuel but only concern would be if it went the same way as Formula Shell did or if the price is ramped up!!
Citroenmad
x 110
Unread post by Citroenmad »
Ive been using it for the past week or so since it has arrived at the local shell garage. I cant say ive noticed a difference but ive not been keeping tabs on MPG in the C5 very much lately. I cant say that it feels any different to drive.
I always use Shell, sometimes BP if i can't find a Shell but i never use anything else. So ill be using this new Shell Fuelsave fuel anyway.
I dont agree that fuel is fuel, they differ, and thats why i stick to the top brands.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 5672
I always used to use Sainsbury's as the Nectar points paid for my Christmas shopping. It was cheap and close by too.
Never had any problems with it but my eldest son, who at the time was driving a Mitsubishi Colt Sport that was very lively, swore by Sainsbury's and claimed that anything else reduced the performance and the economy, sometimes drastically.
x 1240
I buy whatever is cheapest :D
