306 rear axle
keeperlit
306 rear axle
Unread post by keeperlit »
hi i have a 306 estate that failed mot on the rear radis arm.
are these difrent axles from hatchback 306s,
thanks billy
x 94
Unread post by citronut »
hi Billy and welcome
as fare as im aware the hatch only has two toursion bars were as the estate should have three,
were abouts are you,
regards malcolm
keeperlit
hi i am in n,ireland
i looked at mine and there is only toursion bars on my estate
i can get a non abs axle can i fit my abs brakes on to this axle
is there any difrance in phase one and phase two axles
billy
HDI Dave
x 3
Unread post by HDI Dave »
Here's an excellent pug 306 forum I used to frequent when I had one:
http://www.pug306.net/forum/index.php
All dedicated to the 306,standard,modified,tuned,lots of techy expertise.
You'll have to join (free) to see / post etc.
P.s, it's a young persons kinda forum, they have some hilarious rants..ahem...discussions on there :)
1999 Xantia LX 2.0 HDI 110 Rusteration project...
x 94
all 306's are tousion bar suspension,
i think you will need to get one which already has ABS, as the arm's will have a mounting point for the sensors,also the hub have the ABS rotors,
regards malcolm
DHallworth
x 163
Unread post by DHallworth »
I've got one of these sitting in a livestock trailer at the moment from a car I broke for spares.
Only problem is I'm in Glasgow!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Oldpug
x 93
306 rear axle
Unread post by Oldpug »
All 306`s have two torsion bars,one for each radius arm.All you need to know when getting a replacement is ABS? Rear discs or Drums.Have a look at www.sspengineering.co.uk I have used them a number of times for recon Peugeot rear axles without problems.
x 94
acording to PCR of Lancing (citro/pug dismatlers) the estate's have three toursion bars,
regards malcolm
Oldpug
x 93
306 rear axle
A torsion bar is a "spring",Two rear wheels,two rear radius arms,TWO TORSION BARS!! one for each corner.There is a role bar which is hidden inside the cross tube and if its on a parts illustration page may look just like a torsion bar.Sorry to sound like a big head but I`ve stripped 100`s of Peugeot rear axles.
x 8241
As Oldpug says, there's two!
The third, inside the tube, is the Anti Roll Bar. The two bars that are the springs are external to the tube.
So that's where three comes from :wink:
