Call me a chav, but...
Dommo
x 20
Unread post by Dommo »
Does anyone know a good route through the bulkhead for an amplifier power cable on a Xantia Activa CT? Where does the main wiring loom pass through the bulkhead? I know on my 306 I used a big grommet where an air conditioning drain pipe passed through the bulkhead, is there anything similar on the Xantia?
Cheers, Dom.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You'll be taking two cables, won't you - one for ground directly off the battery?
seisporting
Unread post by seisporting »
No you can ground it anywhere with a good earth in the boot area.
Saxo VTR.
robert_e_smart
x 14
Unread post by robert_e_smart »
Hi Dommo,
I routed a cable for a push button starter through the bulkhead where the bonnet release cable goes through. Its just above the clutch pedal in the bulkhead, pull the grommet back, adn you will be able to get your cable through.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
Dommo
x 20
Addo - as seisporting says you ground it anywhere there is a good ground, so where the rear lights ground for example.
Cheers Rob, I'll have a look there for the gromit you mention, and hope the lead I have is long enough ;). How do you find the push start button?
Dom
robert_e_smart
x 14
My Activa wouldn't start on the key, and a spare ignition switch I had was no use either. I had a wire running from the starter solenoid, that I would tickle the battery positive with to start it.
I just used an old heated rear screen switch with the logo polished off and put into one of the spare switch blank locations. Its acting as a push to make switch to make contact between the starter solenoid and the positive terminal. Its a gimmick really, but it enables me to start the car without lifting the bonnet!
1991 BX 16 TGS Auto
Dommo
x 20
Ahh fair enough, so do you still need the key for the immobiliser? I bet that'd have some thieves baffled for a little while!
robert_e_smart
x 14
Yep, I still need the key for the steering lock, and to power up for the immobiliser.
1991 BX 16 TGS Auto
Dommo
x 20
Robert - I used that grommet, it worked well thanks! Took a bit of time to get the cable through but we managed!
Thanks again. Dom.
