Heres one sealey this is a chinese made one from power devil/Nu'tool line up but normally ok.plus they do bosch ones but might have to go upto 24volts to get size/torque?
http://www.toolstop.co.uk/sealey-cp2400 ... ery-p12727
http://www.toolstop.co.uk/bosch-gds18vn ... naked-p286
http://www.toolstop.co.uk/bosch-gds18vn ... naked-p286 this one is the high torque model
Anyone got an impact wrench?
All very interesting, but what I don't want to do is spend out on something that won't do the job
I found this http://www.hss.com/index.php?g=67311&t=zoom which can supply 1000 N/m of torque and is £32 +VAT per day. Looks a bit cumbersome though.
Lexia ponce
Lexia ponce
Hi Stempy, if you are doing the lwr b/js on the bench, this 'lectric impact wrench should not be a problem. Trying to do them on the car with the hub assy still fitted is just awkward.
From my own experience, it is just as quick and easy working on a bench with the hub carrier clamped up in the vice, although I know Citronut will disagree.
H
H
That will be 1" drive stuff and 110volt but they might include in priceStempy wrote:All very interesting, but what I don't want to do is spend out on something that won't do the job
xantia 19td estate 96-7
110v is no problem as I have a transformer, but with it being 1 inch drive I'd need the relevant socket size.
Lexia ponce
Lexia ponce
- Sara Watson's Stalker
- x 93
Hi Stempy, you will struggle to find many places stocking 3/4" or 1" drive sockets as they are normally used on commercial vehicles. You should find a standard 1/2" windy gun will easily cope with these nuts, but if you are going to use a 'lectric impact wrench, you could always get yourself a step-down adaptor to 1/2" and use more readily available 1/2" drive sockets.
If you are going to invest in a few impact sockets, make sure they are all six point not twelve point, not made in the Far East and are not cheap. These usually fragment and can send bits of shrapnel about the workshop. Not nice!
Most of my kit is either Snap-On, Facom, Proto (Canadian) or some UK stuff, although I have bought some ex-military gear that works well. Some of the impact stuff is even chromed.
If you get really desperate, I have a 3/4" drive windy gun, guaranteed to wrench your nuts off!
Addo, 35mm please! 36mm is for bodgers.
H
H
- x 93
So I got every thing fitted bar the lower ball joints which I am still contemplating. New lower arms, track rod ends and ARB bushes. Handling is transformed (not surprising looking at the state of the old bits) and she turns in so quick it almost takes me by surprise.
While I had it apart I also fitted a new aux belt crank pulley which was slipping and squealing. Both jobs went smoothly and were easier that I was expecting.
Foolishly however, I decided to also tackle the perished steering ram LHM return hose. What an absolute bar steward that was. Access is virtually impossible and my solution was to cut off the perished bit at the bottom and use a pipe coupler to join on a length of petrol pipe to the remaining existing pipe. I left the new pipe long enough to put a loop in and connect back onto the ram outlet tube. The loop made it much easier to manoeuvre the pipe into position and will hopefully minimise any stress on the remaining original pipe.
Lexia ponce
Lexia ponce
