c3 2006 brake lights
geelamch
Unread post by geelamch »
Hi,
I have no rear brake lights however the brake light above the centre of the rear window is working,are the brake lights connected or could both have dead bulb at the same time?
spider
x 77
Unread post by spider »
I'd double check the bulbs to start with, its the obvious place to start. :)
It's not unknown for both sides to go and just the middle high level to work, see it a fair bit on all makes.
Andy.
x 1938
Especially if the centre brake light is an LED type.
It's unlikely that both sides went at the same though. More likely that you just haven't noticed!
geelamch
thanks for the advice guys ,
much appreciated
