Hi
the gear change on my 1992 ZX Aura Diesel was getting a bit stiff and noisy so decided to take the gear linkages etc apart to give it a good clean and grease it all. Having done all that the gear change is much better. However a new rattle has developed which I suspect is something to do with the gear linkages as it was not there before...There seems to be quite a lot of play in the rod coming of the gearstick. Is this play supposed to be there? Should I have used some special kind of grease? Any remedies for this rattle?
cheers
ZX Gear Linkages
AndersDK
kaspar
AndersDK
