Thanks!
Citroen Xantia + Peugeot 406 engine = ?
igor253
OK, I have a friend who used to drive a Peugeot 406 2.0 hdi, but recently he totaled his car and now he's selling what's left of it, like the engine. Now he wants to sell it to me, because my Citroen Xantia 1.9TD engine is, well, let's just say it's used up
, and I need a new one. But sense this is my friend he is willing to sell it to me for a fair price. Now the question. Is it even possible to put a 406 engine into a Xantia, sense they are almost the same cars?
Thanks!
Thanks!
KP
- x 27
spider
- x 77
I answered your topic in the Peugeot forum
But it is not straightforward (regardless of what came from where or where it is going to) to do a XUDT to HDi conversion. Physically bolting it in (assuming gearbox / clutch is OK) is the easy bit, making it run properly is quite another.
Doing a HDi to XUDT is a bit easier as you are throwing a lot of things out (electronics mostly), although there's still a lot of things to consider (exhausts and pipework etc for one)
It would be best to obtain another XUDT and fit that
, remember you will need (probably) all your ancillaries off your existing engine as 406's do not have hydraulics etc.
And possibly manifolds too, quite likely if donor was not Xantia or 406.
Andy.
igor253
Thanks for repling,KP wrote:There is a lot of work for this as its not a straight swap, even more so for the 110 engine. best to either buy it cheap and ebay it or keep it for another motor.
I know it won't be easy and that there is a lot of work and I know it would be easier to just put in another TD engine. But, the reason I want a HDi is simple, more power and newer engine, sense I dont have money for a new car
Thanks!
citrov6
Hydraulics are run off the engine so it will need an appropriate bracket and belt there. If it is not in the correct location you will need customised pipework.
The electronics is also part of the car, it wont work without the clocks, key and ecu
Love my black v6 xant - only one with cream coloured leather too!
