Xantia Rear Suspension Pipes
reservex
I have got a leak has any one any experience of replacing the rear suspension pipes on a xantia?
- x 1240
reservex
- x 1240
I can only speak with experience of the XM, that has two large bolts each side of the subframe, slacken of by a few turns the ones on the opposite side to the one you want to drop, put a jack under the one you are dropping, take the weight then remove the bolts on that side and lower it, the pipes have enough give in them to allow you to be able to see in and get your hands there.
reservex
