The mention of Injector cleaner killed the thread
KevMayer
Unread post by KevMayer »
I've mentioned using an injector cleaning fluid on 3 threads now and each time the meer mention of using the fluid has killed the thread.
And, as I've mentioned it again I don't suppose there'll be a reply to this thread either.... LOL
Cheers, Kev
h2ocooler
Unread post by h2ocooler »
Well Im going to try some............so you have got one reply........... :D
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
KevMayer
Thanks for that...... do you ever get the feeling there's nobody listening.
My sanity is restored.
Cheers, Kev
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
I am looking at using an "injector cleaning" addative for my 2.1,any ideas as to which is the best product to use :?
Colin
KevMayer
I've recently used one from Halfords called 'Comma Diesel Magic' and to be honest I'm very impressed with the results. I wish I'd used it ages ago. I really feel that it's cleared out some rubbish.
Cheers, Kev
andmcit
x 30
Unread post by andmcit »
Cunning plan starting a thread mentioning injector cleaner - must be a
runaway thread over 5 pages now as an equal and opposite effect to the
x3 previous ones! :wink:
I've used Redex on the petrols so would expect the dieseol version to do
the job too - cheaper in Asda than anywhere else I've found.
Andrew
x 5672
cachaciero
x 9
Unread post by cachaciero »
Trip to Halfrauds tomorrow then! :-)
Try anything once if theres a chance of improving consumption or do I mean reducing consumption
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
KevMayer
Forte is good.... that would work well too.
I just think the principle of giving your injectors a good clear out could be the key to a lot of problems.
Cheers, Kev
pug_owner2002
x 3
Unread post by pug_owner2002 »
I use the comma diesel magic.
Although I think the forte stuff is quite good too. The peugeot dealer around here used to do the "forte treatment" when my old 306 was service and charged a rip off price to do it too.
R Reg Phase 2 306 DTurbo (Blaze Yellow) (Sold)
X Reg Phase 3 306 1.4 LX (Sold)
03 Renault Scenic Dynamique +
03 Seat Leon 1.9 TDi
52 Nissan Almera 1.8 sport+
acrowot
Unread post by acrowot »
Kev, Just put some Redex injector cleaner in mine, only done about 30 miles since, will let you know the outcome. I also bought one of the MAF sensors the same as the one you bought, when I fitted it the engine became very lumpy on tickover so I put the old one back in, do you have to do anything with a Lexia after the change?
John
C5 HDI 110 SX 122000 ESTATE
C5 HDI 2.2 2003 EXCLUSIVE ESTATE 151000 MILES
KevMayer
I've changed my MAF twice and I didn't have to do anything each time. Maybe it takes a time for the ECU to adjust. Possibly try disconnecting the battery for 30 seconds and see if it resets any learned parameters.
Redex is more of a gradual/progressive treatment. The treatment I'm talking about is more of a one off intensive clear out.
Cheers, Kev
wright
Unread post by wright »
the best injector cleaner is called dipetane it can be used in petrol or diesel, i'm using it for years can be got in ireland in 1 litre for about €10 or 5 litre for around €35, 1 litre treats around 10 or 15 fills, you can't put too much in, i put a strong dose in every now and then
x 5672
wright wrote:the best injector cleaner is called dipetane it can be used in petrol or diesel, i'm using it for years can be got in ireland in 1 litre for about €10 or 5 litre for around €35, 1 litre treats around 10 or 15 fills, you can't put too much in, i put a strong dose in every now and then
That's interesting, I will hunt some of that down and give it a try.
Dipetane
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
In all four of our cars I occasionally use Millers Sport 4 but always make sure I give a more than the recommended dose in the weeks before each MOT. They sail through the smoke test.
I believe Sport 4 has been replaced by this:-
http://www.millersoils.net/M3_cgi/mille ... e&cart_id=
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
