Xantia Alarms
landcrab
Xantia Alarms
Unread post by landcrab »
The alarm on my 1999 S2 Xantia Estate goes off at the slightest gust of wind.
How can I disable it so it never goes off again???
Why are alarms fitted to cars anyway?.Does anybody ever take any notice when they go off?
On my old ZX it was simply a matter of inserting the key into a switch under the bonnet and turning it off.The Xantia does not appear to have such a switch!
Any suggestions would be most welcome.
Bryan.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
The false alarms are more than likely due to duff ultrasonic sensors, you can disable them when you get out of the car by pressing the button on the right side of the dash, if you want to turn off the alarm you'll need someone with a Lexia to do that.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1463
Unread post by xantia_v6 »
What happens if you just unplug one or other of the ultrasonic devices?
landcrab
Xantia Alarms
Thanks for the prompt replies. Where do I find the Ultrasonic Sensors.
Or maybe there is a fuse that can be removed!!
Bryan
x 1055
Unread post by wheeler »
xantia_v6 wrote:What happens if you just unplug one or other of the ultrasonic devices?
If it's the sensors that are faulty then that should stop the alarm going off.
If you remove the fuse you will likley loose everything else controled by the CPH. C/locking, interior lighting & the imobiliser.
landcrab
Xantia Alarms
Where are the sensors located?
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
landcrab, in the inner front door upper triangles, i.e. the inner of the wing mirrors..
hope that helps
John
landcrab
Xantia Alarms
Thanks John
