I have a Flat Spot on my 2001 2.2 HDi??
All filters are new, DPF is fine, have tried a different AFM but to no avail.
It can be quite dangerous if not ready for it.
It can cause you to stall the car at lights etc but also can be very dangerous at T junctions when pulling out only for the car to just die half way across - the only sure fire way to do it safely is with plenty of throttle and with the passengers suffering from the unexpected g-force!!
Any ideas anyone??
Flat Spot on C5 HDi 2.2
corsehf
Andy
2003 C5 2.2HDi Exclusive SE Est
2001 C5 2.2HDi SX Est (gone to C5 Heaven!)
2001 Omega 2.2DTi Est (stolen by Ex!!)
1997 Xantia 2.1TD SX
1994 ZX TD Volcane
Lancia Stratos Replica
1994 ZX TD Volcane
- x 5672
corsehf
I have read on here somewhere about the cable may need adjusting but i did check that and it appeared ok.
I did remove the pot to see if the contacts were worn but it was a sealed unit. Other than getting a spare, is there another way of checking?
Andy
1994 ZX TD Volcane
1994 ZX TD Volcane
- x 5672
KevMayer
I've had this on my C5 2.2 Hdi.
Looking around the internet I concluded that it may be a problem with dirty injectors, so, I first tried putting loads of Redex in the tank and this seemed to clear it.
I got the same symptons recently so went to Halfords and got some 'Comma Diesel Magic'. This treatment fluid appears to have good reviews so I poored it all in with 20 ltrs of diesel.
The jury is still out, but, my C5 seems to run much better.
The Diesel Magic cost £5.99 so is worth a go.
Cheers, Kev
KevMayer
