citroen c5 comms
axford
citroen c5 comms
Unread post by axford »
Hi all,i,ve got the old problem of a mark one c5 with comms problem - lights switching on when indicating etc.
Does any one know if i can swap a later version ie from a post facelift - after 2004 model wiper stalk (comms).
The wires are different colours but it looks the same.
Any info would be much appreciated .Chris
x 1053
Unread post by wheeler »
You can't swap the com's units between a mk1 & 2.
Citroenmad
x 110
Unread post by Citroenmad »
I had this exact problem ith mine.
I got a new comms from the dealers for £180. As said, you cant swap between S1 and 2.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
monkfish
same
Unread post by monkfish »
i had the same problem all i did was go to a scrappy and get the small metal ring that causes all the problems and changed it easy peasy and quick
c5 2.2 hdi sx
xantia 1.8 sx
bx 1.9 gti 8v
axford
monkfish
Hi,thanks for the info but could you expand on ye oldie metal ring - did you have to buy the whole comms unit and where does it sit in the unit and is it easy to replace ? thanks
