ok i agree with that
regards malcolm
Uneven breaking
Kowalski
cox377
- x 94
cox377
- x 94
Old-Guy
- x 32
Malcolm is right; it's essential to get around a qtr litre of LHM out of each rear brake nipple to purge the brake lines of 'air'. If no bubbles from any of the nipples (and you're still convinced there's something 'odd' about the brakes, I'd take a good look at the front calipers to make sure that the calipers slide easily on their pins AND that the inner pads move freely in the calipers with no hollows in the lower seats for the pad back-plates. On Xantias more than other cars, the front brakes seem to do even more of the work than the rears - in 30,000 miles in my hands, I have yet to need to change the rear pads, but I've fitted 2 new sets of front pads and new front discs too the second time.
Guy
Guy
cox377
MJM
I had a similar problem on a BX GTI where the rear would dip under heavy braking. A local indy traced the fault to a failed accumulator sphere. The fronts ran out of pressure as the engine speed fell away but the rear brakes ran on for a while on rear suspension pressure. Changing the accumulator sphere cured the problem.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
cox377
The accumulator sphere is the front centre isnt it? I replaced this one about 8 months ago. Hopefully it doesnt need doing again.MJM wrote:I had a similar problem on a BX GTI where the rear would dip under heavy braking. A local indy traced the fault to a failed accumulator sphere. The fronts ran out of pressure as the engine speed fell away but the rear brakes ran on for a while on rear suspension pressure. Changing the accumulator sphere cured the problem.
As was previously mentioned that it might be the rear centre, GSF gives me
ANTISINK SPHERE-REAR
SPHERE-REAR CENTRE
I want to ensure I'm getting the right one before I buy, as you can imagine
CoXen
- x 94
yep thats the right one James
you will know asa it only has a hole in the worrking end big enough for a 9mm (spanner size ) pipe nut,
i find the easyest way to remove/re/fit these, is to just loosen the pipe nut a bit, then unscrew the sphere whilst holding the pipe nut with a flairnut spanner, dont forget to retrive the pipe seal fron in the end of the old sphere, and pluck ant loose strands of rubber off before re/useing it,
regards mlcolm
regards mlcolm
- x 94
Old-Guy
- x 32
A rather more informative list of spheres HERE. But your best bet is to e-mail an enquiry to GSF quoting year and model - that way any mistake is theirs!
