Uneven breaking
cox377
Uneven breaking
Unread post by cox377 »
Hello Guys,
I’ve got a query, does anyone know what would cause uneven front / rear braking, or in other words over heavy rear braking on a Mark 2 Xantia. The brakes were working fine and the pads are fine all round.
I think I’ve noticed the suspension being slightly off balance as well when driving along, but that maybe in my head.
Much appreciated as always
coXen
x 1240
Unread post by Peter.N. »
Are the rear wheels locking up?
cox377
they have done when really anchoring up.
x 94
Unread post by citronut »
its not just when you have the car loaded up with building material and a trailer full as well,
regards malcolm
cox377
nope, she was carrying no weight :D
I've noticed the back going down a little bit when breaking, didn't realise quite how much breaking until i had to anchor up.
cox377
I have added another litre of LHM last night as I know she was running a touch low. No change. Is there a common fault that might cause this on these motors?
CoXen
x 94
maybe your centre rear shphere is flat, so your brakes are drawing from the rear suspension presure,
this could also be why some people call this sphere an anti sink sphere,
as it is actualy a rear brake reserve presure back up,
regards malcolm
G4EIY
Unread post by G4EIY »
Loosing LHM quickly from the reservoir without any visible external leaks, is a sure sign that one or more spheres have lost nitrogen into the system.
When this occurs, it does produce rear end drop on braking.
Good luck
Brian - 86 Visa 17D Sorn(192K)/ 86 BX 17RD (220K) Scrapped/ 92 BX 17TZD Turbo Diesel (191K)
96 306 XRDT (174K)
cox377
okay, so I need to change out the centre sphere? the front two spheres look quite new, I've changed the front centre as well. I think the centre one looks the oldest out of the lot.
Malcolm,
Do you have any means of testing the sphere?
x 1461
Unread post by xantia_v6 »
I don't think that any of the spheres can cause the brake balance to be wrong. Air (or nitrogen) in the brake lines can cause odd effects, but bleeding will fix that.
The brake balance is entirely controlled by the doseur valve.
Can you describe the symptoms more precisely, a MK2 Xantia will have ABS, so it should not be possible to lock any of the wheels without the ABS kicking in. (and then how do you know it was a rear wheel that locked?)
dnsey
x 19
Unread post by dnsey »
They usually do, as they live in a relatively clean, dry environment.
The best guide if in doubt, short of a proper pressure check, is to look for date codes
Dommo
x 20
Unread post by Dommo »
How old is 'too' old? My front corner spheres were made in 07 I believe, and they feel as though they could do with being changed?
Citroenmad
x 110
Unread post by Citroenmad »
Really sphere dates dont have much of an importance, as on the shelf they lose very little, if any, pressure. When fitted to the car they obviously do lose pressure.
Its often said that 3 years or 30K miles is a good time to swap/regas spheres.
A pressure check is the only real way to check a sphere, even very old spheres can be good ones.
The brake problem could well be nitrogen or air in the system, which does cause odd effects.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 94
xantia_v6 wrote
"The brake balance is entirely controlled by the doseur valve"
that may be so but the rear suspension dose return via the doseur valve
regards malvolm
x 1461
regards malvolm
No argument with that, but the thread seemed to be going off on a wild goose chase...
I think the advice has to be to bleed the brakes and if the problem persistes, get a better description of the symptoms.
