Low saps! whassit all mean?
veralum
is this better for our cars? if so why? will it give m an extra 10 bhp?
- x 8427
- x 94
- x 1943
It's oil that's been developed for engines with particle filters. Basically the oil, when burnt in the engine, produces less ash to clog the filter up.
- x 8427
- x 1943
We're not talking two-strokes here! All engines burn oil, even if it's in miniscule amounts. Low SAPS (Sulphated Ash, Phosphorus and Sulphur) oil is designed to reduce even further the solid particulates that any engine produces.
In fact there's a thread I've read somewhere (maybe not this forum
) discussing the merits of using two-stroke oil as an additive to derv on the grounds that, being designed for two-stroke engine, it will produce less particulates. Me, I'm not so sure.
jimleshed
I would have thought that 2 stroke oil would cause as many problems as ordinary oils?
I used to work on 2 stroke bikes a lot, and the exhausts were always needing de-coking, and from the amount of blue smoke they create you can see why....I guess the blue smoke might look better than standard diesel black though!
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
- x 1943
The thread was discussing ways of adding lubricity to low sulphur derv. Like I say, I'm not convinced.
rmunns
- x 9
Sounds like another con. No doubt much more expensive. More and more I am of the belief that the golden age of cars has passed. The last few years has seen many many instances of gruesomely complicated servicing needs. IMHO the benefits are nowhere near worthwhile. Including emissions. I've resolved to always buy cars made before 2000.
At 150gm of CO2 per km an average engine will emit about 40tonnes of CO2 in its lifetime. That would only fill a cube of 27metres.
13 Million cars in UK emit about 40Million tonnes of CO2 in a year. That's a 270 metre cube full.
Doesn't seem a lot to me.
Figures are worked out at a density for CO2 of 2kg/cubicmetre
[/u]
[/u]
- x 8427
Thanks Paul for the explanations
I'm not convinced 2-stroke oil is a good replacement for sulphur in diesel either! After all, it's designed to do a very specific and very different job.
I'd have thought still that the amount of oil burned in a modern engine would be so tiny as to be of no account. Maybe modern engines burn more than our XU and ES engines perhaps. I know I never have to top up any of mine between changes but that's not the case with my neighbour's Passat or indeed my other neighbour's Focus so perhaps the problem is there..
I recall that modern oils have a lot less zinc in them these days. Zinc is/was a very effective anti-wear additive but is not good for the health of anything if burned. Also, I believe zinc has a similar effect on cats to lead.
I'm of the school of thought that there is a lot to be said for keeping a pre-2000 car on the go, just a shame we get stung so hard for road tax
- x 5676
Mine uses negligible amounts and doesn't get topped up between services, although servicing is done at less than the recommended 12,000 miles.CitroJim wrote: I'd have thought still that the amount of oil burned in a modern engine would be so tiny as to be of no account. Maybe modern engines burn more than our XU and ES engines perhaps. I know I never have to top up any of mine between changes but that's not the case with my neighbour's Passat or indeed my other neighbour's Focus so perhaps the problem is there..
jgra1
- (Donor 2021)
- x 36
