NOT SUSPENSION ONES!!
Electro valves under the bonnet that controll Vaccumm, for Turbo, EGR Valve and various flaps..
Anyone know how much these are? Car is a 2.2 HDi Tiptronic, 2004, and needs 3 of them..
Paul
C5 Electro Valves 2.2 HDi 2004
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
citroenxm
- Fallen Hero
- x 70
Not bothered as long as they work.. I realise a working life of a small vac valve like these can be extreamilly varible!
Whats the damage for used ones?? Whats the likely chance of them working?
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
cachaciero
- x 9
As I recall £37.00 each eighteen months ago.
But I have to say that I would regard the failure of one as unusual but three..!
are you sure that they are U/S.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
citroenxm
- Fallen Hero
- x 70
The valves should get warm when the ignition is on, to indicate functuality, one is, the other 3 are not...
Ones a Waste gate controller, second is the EGR vlave controller, the third the throttle butterfly. but ALL 3 valves are the same thing..
Cheers
Paul
Cheers
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
OnlineRichardW
- x 1488
citroenxm
- Fallen Hero
- x 70
Thanks Richard..
Looking at the car: Brake servo resoviour.. theres TWO Stacked ontop of each other, then a 3rd to the right of those two... Its the two stacked that are not working..
Then theres a 3rd on the side of the head... just under the air intake pipe to turbo..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
cachaciero
- x 9
I don't think that I would consider perceived temperature as a reliable measure of whether they are good or not.citroenxm wrote:The valves should get warm when the ignition is on, to indicate functuality, one is, the other 3 are not...
Cheers
Paul
The solenoids themselves are in some cases (all?)driven with a pulsed signal with variable mark space ratio.
Certainly neither the turbo (waste gate) or the EGR will be active at idle.
A Lexia would give a much better indication of whether they are good or bad electrically although a resistance test will likely tell you as much, then a vac gauge tee'd into the output side of the respective valve and the valve energised either using the Lexia or an external supply and vacuum levels checked would be the way I would go. I am saying all this because in all that I have read and my own limited experience they are not a high failure item.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
cachaciero
- x 9
The two stacked ones one will be EGR ( I think!) mounted on left high side of bracket and the other is the turbo control mounted on the back and slightly lower on the bracket, as I said elewhere these will not be energised at idle.citroenxm wrote:Thanks Richard..
swirl valve control
cachaciero
Paul
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
citroenxm
- Fallen Hero
- x 70
Lexia session all done thanks!
And it is showing 3 dead! Hence me asking for advice on price or supply!
Anyone out there with a 2.2 they can take photos for me, It seemstheres also something missing from the LEFT side of the Servo resoviour, as theres two Vac pipes not connected to anything..
Someone else has been here before me messing around.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1052
Whats the chances of all 3 of them failing ?? I would have thought it highly unlikely. I would also agree that the fact one is warmer is not a good indicator as to if they are operational. Have you done any other checks like seeing if they are being powered up ? my first thoughts if i saw faults with all 3 coming up would be that they are not being powered up as they all share a common feed. just because lexia shows a fault code with them doesent neccisarily mean they are faulty. Can you auctuate them with Lexia ?
citroenxm
- Fallen Hero
- x 70
Nope I cant...
For the cost of the car and the price of the valves, its relativly worth it.
This same thing happend on a Xantia HDi 110, when the Turbo Wastegate Valve failled... The EGR one was warm, the Wastegate one cold..
Swapped for another, both warm, problem went away.
Ive also been informed from a reliable source that they should warm when working!
Thanks guys for advice.. Good stuff..
Regards
Paul
Regards
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
