Hi I am looking for some advice if possible. I have a xantia V6 and the
suspension will not rise at all. I had a slight leak from the seal on the HP at the steering output and replaced the o-ring and I also replaced the LHM fluid with hydraurincage flushing fluid. I drove the car that day approximately 40 miles and all felt great. The next day I
headed for work as ususal and the first junction I came to the brakes had little effect and then after hard pushing had some effect. I drove the rest of the way using mainly the hand brake (probably not the best idea). After work heading home the suspension started to play up sinking at the front. When I got home (very slowly) I tried lowering the suspension and I have never been able to get it to rise again! The power steering still works.
After reading this forum it looks like the side of the HP pump that drives the brakes/suspension has gone? I have also ran the car a while then opened the valve on the accumulator and there was no release of pressure. Could it be the accumulator? Can anyone suggest anything I can try or is it just a new pump?
Any help would be great as I have been cycling to work for 3 weeks now. (could be a blessing in disguise!)
Suspension will not rise at all!
- x 1459
Maybe its a Scottish thing? See this saga.
Can you tell us exactly what you did to your pump, and which bits you removed before the trouble started?
I am a bit surprised that you did not mention the STOP light being on.
A faulty regulator valve could also cause the symptoms you are seeing (you haven't lost the ball and spring have you?)
- x 94
if the ball and spring/plundger were lost or not in corectly the car would not have appeared to been fine the first day,
but i do agree it must be linked to what you have done,
did some dirt get into the pump whilst appart,
how clean are the fluid and filters in the tank,
is there a crack in the sucktion pick up rubber hose at the pump, this is the pipe between the pump and tank
regards malcolm
regards malcolm
co04pow
- x 3
Thanks for the speedy reply!!!!!!!
Ok I removed the 12mm brake pipe style hard pipe on the lefrt of the top of the pump.
Then the if I remember 20mm hex under this and replaced the o-ring that was leaking.
I have been to the car today and removed this again after reading your ball and spring/plundger reply.
The spring has broken! Using a magnetic screw driver I have removed the spring parts, ball and plundger.
I take it the plundger is the bit that looks like a cradle for the ball.
So have I disturbed the ball/plundger and have crushed the spring while tightening down the 20mm hex part!
Is there bits of spring inside the pump!!!!!!
I have phoned Citroen already and they don't list the ball and spring/plundger only the whole pump. Any idea's where I can get one?
As for the STOP light it has never been on ever! What could be the cause of this apart from the light in the dash been blown?
Thanks again for the speedy reply looking forward to more wisdom!
Owen
Owen
2000 W reg Xantia V6 Exclusive (Green)
2000 X reg Xantia 2.0 HDi SX (Dark Grey)
1999 V reg Xantia 2.0 HDi Exclusive (Dark Grey)
1998 R reg Xantia Estate 2.1TD SX (Silver)
1996 P reg Xantia 1.9TD SX (White)
1996 P reg Xantia 1.9TD LX (Red)
1994 L reg Xantia 1.9TD LX (Silver)
- x 94
lexi
- x 133
The spring is specific to the V6 pump as is the tiny top hat valve for holding the ball.
You would think that a similar spring could be gotten from a specialist supplier of springs somewhere.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 94
OnlineCitroJim
- x 8397
Have a look at the photo half way down this page... Malcolm!citronut wrote:what is the diference between the ball and pludger from a V6 pump to non V6,
regards malcolm
Looks like the V6 has bigger balls...
A Spring Specialist Lexi? Yes, all they'd need is free length, gauge diamater and rate...
I reckon a 1.9T spring should do at a push. At least to get you going again.
co04pow
- x 3
Hi,
I called Martin at Pleiades he was very helpful but does not have any v6 pumps but is sending me a 1.9 TD spring to try.
Will let you know how I get on.
Thanks again for the advice.
co04pow
- x 3
Hi, Spoke to Martin at paleides and he sent me a spring/plunger/ball for a 1.9TD. I have fitted it all seems well. I have done about 100 miles so far. I will let you know long term results.
Thanks agian for the help
Owen
Owen
lexi
- x 133
Brilliant!
Why is the V6 spring longer then? The cup holding the ball also has holes on the sides.... for more flow presumably?. Mmm.? Only Citroen know these answers
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Pleiades
Hi Owen.
Great to see that all is working fine again.
I dont realy know why the spring is longer on the V6 pump, the stroke length is the same as all other pumps so I guess that the differences will not matter.
As for the holes in the cup bit, this is just a design thing, I guess that one place that makes these bits does it one way and another does it different, as some pumps have one design and some the other, there is no pattern to it.
Regards
Martin.
Regards
Martin.
vince
- x 13
