Thanks for taking the time to think about it! I really hope i dont have to go leak hunting, i wouldnt even no where to start
I shall report back hopefully witht eh results of the pressure test!
Sorry I know this is a topic from a long while ago, but if these criteria are correct, what do we think is the issue with my 306?admiral51 wrote: Hi dave
That is setting alarm bells ringing![]()
Dont take this as gospel but this is how i understand the system to work
1.Everything is controlled by the information sent/recieved by the Bitron sensor
2.The A/C needs the following things to be inplace before it will start
3.The A/C button must be switched to the on position
4.The interior fan must be switched on/auto
4a.Caviat on MK2 cars if the interior slider is set to demist screen then the A/C will switch on
5.Both fans must run at slow speed.Bitron sensor cannot tell if fans are actually running it only knows if power has been succesfully applied to them
6.Power is then sent to HP/LP switch
7.If HP if detected then both fans are set to full speed and A/C disabled until HP is no longer present
8.LP in system will prevent compressor from engaging
If as you say both fans go high speed when you engage the A/C then i would point the blame at the switch as this is saying the system is under HP even though it hasnt started.
Try starting the A/C with the pressure switch plug disconnected and see what happens to the fans.The compressor shouldnt kick in as the Bitron is not recieving any information from the HP/LP switch so cant commit to doing anything other than starting the fans at slow speed something it should do before it sends power to the HP/LP switch.
You should (hopefully) find that the fans spin at slow speed and you will then be able to bridge the 2 thick wires in the plug to engage the compressor clutch.
If the fans spins at full speed with the plug pulled then i would suspect a wiring fault/short to ground in the thin wires leading to plug
Hope this sort of helps
Colin
PS If it is the switch i think i have a good spare i can pop in the post to you FOC
Sorry for the questions, it's just confusing me! Stupid caradmiral51 wrote:Hi Dom
First off im a not an A/C expert all knowledge has been gained from this forum and practical repairs on a Xantia![]()
A little unsure how you can be sure the compressor is engaged without the engine running with the key in the accessories position unless ive misread your post. You can hear the compressor click, it's very loud! Probably easier to hear in a 306 than a Xantia, they didn't do a particularly good job of sound proofing the 1.9TD 306 engine bay. But yeah, you can hear it click in, and hear it click off with the engine off (the sound of it clicking on is louder than it clicking off)
For my sins i am trying to collate as much info on the Xantia (sorry thats all i know about) A/C system that has been posted on the forum but have a look at This
I cant find the link at the moment but there is a purple/violet relay in the fusebox by the abs ECU that controls the cut in/out of the A/C.It has been known to develop a fault . As it happens, I know the relay you're talking about, and I can feel that click on/off when the compressor engages, so something is telling that relay to turn off
It could be that your system is borderline on gas and with the revs higher than 1200 the sensor is assuming you are travelling and can cope with the increase of heat in the system.As soon as you drop to idle the heat within the system will increase and its safety feature will be to disengage the A/C . I wondered about this, but I don't know how the AC system knows the engine speed, there's nothing to my knowledge that could tell the AC system what the engine speed is, there's no wires coming from the fuel pump or anything, so unless it uses the same sender as the clocks I don't think it knows engine speed?
Like i say im no expert,just trying to remember what ive gleaned from the forum
Colin
Yeah, I thought that. And I don't think it's pressure related as I bypassed the pressostat thing (for testing purposes) a good few months ago and from what I remember, it still had the same issue. But I ought to do this test again to check as I can't remember if it did fix the problem or notClogzz wrote:If the air is ice cold above 1250 rpm, there’s plenty to compress, and a good load on the accessory belt.
If the belt is slightly loose, the heaviest driven accessory will slip first.
The belt on SWMBO’s Nissan Pulsar was slightly loose, and we only found out because there was a slight whine above 50 mph.
Hi Jim, could help me find the relay 8015 in your diagram (compressor cut off relay (controlled by coolant temperature control unit) ). Is it behind the fuse box?CitroJim wrote:Hi Dave,
This is the circuit of the MK2 aircon system and the compressor clutch is item 8020.
It should help track it down. If you need the harness diagram, let me know...
