Lexia where can i get one
carlberry64
Unread post by carlberry64 »
hi all
got service light on the dash this is the word SERVICE in green and not the service spanner, its on my 2006 C5 Design and after reading post the name Lexia come up all the time.
i take it the Lexia is the diagnostics and wondered if it was worth getting one and where i could purches one from.
cheers
carl
h2ocooler
Re: Lexia where can i get one
Unread post by h2ocooler »
carlberry64 wrote:hi all
cheers
It depends on a few things, Where you are for one, if your in the UK there are a number of members that have them (im one of them) that will plug cars in, all you need to do is let us know where you are.
They are avaiable on bay of the E for anything from £150 upwards, you will also need a laptop with USB and windows XP but that depends on how much you are willing to pay and how much of a DIY spanner you are.
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
boristhespie
x 4
Unread post by boristhespie »
What should you look out for as I have heard that some are knockoffs?
Is this a Lexia 3 by the way? As there are loads of them for not very much.
C'est pas possible!
carlberry64
Rob
hi rob
i live in Bolton Gtr Manchester
i am ok DIY spanner
what should i look for ie the software and also the connection lead?
cheers
carl
carlberry64
boristhespie wrote:What should you look out for as I have heard that some are knockoffs?
hi boristhespie
not sure on the lexia version thats what i need advice on i have seen them on the bay but not sure what connectionc for car to laptop i need, is it just a lead or do i need the lot
* Main interface
* Power supply (110-220V)
* OBD-2 cable
* USB cable
* Software CD
cheers
carl
h2ocooler
Rob
hi rob
i am ok DIY spanner
cheers
The one I bought was a LEXIA 3, it came with the unit, USB cables, 16 pin OBD 11 plug and the older 32 pin adaptor plug plus LEXIA and Peugeot Planet software, only tried it on my C5 but works fine, had no problems setting it up either. I paid £200 for it but it was a UK supplier and arrived the next day. I could have got the same? (less the 32 pin adaptor) from hong kong for £139 but decided that might be asking for trouble.
I use a basic Laptop (celeron CPU with 1Gb ram) and windows XP
Here is a link to the one I bought
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
You can buy the real LEXIA but they would be a bit more I think plus they would be well USED.
Rob
boristhespie
x 4
yOU JUST NEED TO KNOW WHAT TO DO WITH THE CODES ETC
C'est pas possible!
h2ocooler
boristhespie wrote:yOU JUST NEED TO KNOW WHAT TO DO WITH THE CODES ETC
Agreed, some of the codes are confusing but it does seem to give alot of information in plain talk as well.
Rob
steelcityuk
Unread post by steelcityuk »
This is the sort of info you get-
Most Lexia's are fakes (Chinese clones). I doubt a non dealer could buy one directly and then the price would be into four figures. Mine's a clone.
Steve.
not applicable
x 1905
A lexia can produce a barrel load of data but the question is, what can you do with it?
Where does one find the information of what is within normal parameters and what needs looking at? It's all very well knowing that an injector is giving 5 pico litres per rev (I'm making that up!) but what does it mean?
carlberry64
thanks for your replys has anyone had the green service light on and for what reason would it come on.
my car had an airbag go off would this put it on.
cheers
carl
x 1052
Unread post by wheeler »
Yes the service light would normally illuminate with an airbag fault.
carlberry64
wheeler wrote:Yes the service light would normally illuminate with an airbag fault.
would the service light need resetting once the airbag fault and modual had been fixed. Or would it be ok
cheers
carl
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Paul-R wrote:A lexia can produce a barrel load of data but the question is, what can you do with it?
In order to understand what that data means and how to determine what is right or wrong you need the Citroën diagnostic manual for that particular model/system you are testing.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1905
DickieG wrote:In order to understand what that data means and how to determine what is right or wrong you need the Citroën diagnostic manual for that particular model/system you are testing.
Hmmmm, and how easy is it to obtain one of those I wonder.
