Xantia ABS light intermitent
mark21td
Unread post by mark21td »
I have an intermitent fault with my ABS, the light stays on sometimes,
Sometimes it goes out while driveing but sometimes it stays on for a few days, other times it doesn't come on for weeks.
It goes through it's normal diagnoses, goes out and then comes back on.
It's been checked out on a Lexia by DickyG (thanks agine mate) and showed no faults at the time.
The car is due it's MOT soon so I need to get it sorted quick.
Any ideas.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
x 8391
Mark, I'd be very tempted to suspect a sensor is borderline.
Get an accurate (ish) ohm meter on to them and check their DC resistances. If one looks a bit high compared to the others, that's the one that may be giving the fault.
Also, give your dragon's teeth a good clean. Muck and dirt on these and on the pole faces of the sensors themselves can give problems.
mark21td
Thanks jim, I'll have a look tomorow.
mark21td
Ok I've checked the resistance on all the sensors
FR = 1.092
FL = 1.102
RR = 1.094
RL = 1.103
So they all seem quite closely matched,
but what a sod of a job that was, who decided to put the conectors there :grr:
I cleaned up the frunt sensors and the drivesharts have been replaced in the larst couple of years so the teeth are nice and clean.
I couldn't get the rear sensors out as there stuck fast, but I did clean up the teeth as they were quite rusty.
Not had chance for a test drive yet so I'll see how it goes tomorrow.
Xaccers
x 188
Unread post by Xaccers »
You didn't test them by disconnecting each one did you?
Not that there's anything wrong with that, but it's a PITA.
You can just disconnect the ABS ECU connetor and test there.
There are pin diagrams for both S1 and S2 Xantias in other ABS threads.
DIY sphere tool
mark21td
Xac wrote:You didn't test them by disconnecting each one did you?
Yes I did it the hard way, while spraping up my arms I was thinking there must be an easier way to do this, I know I should have done some reading first #-o
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Mark, give me a shout if you want me to carry out a diagnostic test for you.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
mark21td
DickieG wrote:Mark, give me a shout if you want me to carry out a diagnostic test for you.
Yes please Richard, as the light was still coming on this morning, but went out after a 35 mile drive, I just can't work it out.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
have you actually tried a Safe Emgergency stop to see if the ABS works at all?? Light on or off??
I had a Xantia S1 estate, light out, but still Skidded!!
Also had that on a Hatch.. Were as on my XM, light on and ABS still works!!
Paul
A very sad...
1994 XM 2.1 d auto
mark21td
I know it works when the light is out, but I've never checked it with the light on.
Is it an MOT fauil if the light is on ?
citroenxm
Fallen Hero
x 70
Absolutly! Weither the system works or not - light on instant fail...
Paul
A very sad...
1994 XM 2.1 d auto
Old-Guy
x 24
Unread post by Old-Guy »
Had exactly the same fault on both of our Xantias - 'faulty' O/S/F sensor. Cost my daughter a mint to have her's diagnosed and a new sensor fitted. Fault reappeared after a couple of months. Permanent cure for both cars was to unplug at the ECU and clean-up the connectors - I also checked and cleaned the individual connector for the 'faulty' sensor on our Xantia. Strangely, the fault re-appeared for a few minutes a few weeks ago, but I may have confused the ECU by briefly spinning one front wheel on loose gravel when pulling away in a hurry.
mark21td
DickyG has just plugged my Xant in and found the F/N/S sensor is at fault.
Thanks again Richard.
Just had a look on ebay and found this
http://cgi.ebay.co.uk/Brand-New-Citroen ... 255875c4d4
Anyone used these people before ?
Are they any good ?
MJM
Unread post by MJM »
Yes, same sensor fns. It arrived in a couple of days. It looked o/e quality. (You can tell by the standard of the plastic mouldings) It was a perfect fit and worked with no problem.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
mark21td
Thanks MJM, I'll order one now.
