GTi or Mi16?
philhoward
GTi or Mi16?
Unread post by philhoward »
Just bought some Alloy wheels which were supposedly off a 106 GTi, but looking at them I'm pretty sure they're actually off a 405 Mi16; can anyone confirm which is correct?
Question 2 - what size/length/thread are the bolts, as I didn't get them with the wheels?
nickm
Unread post by nickm »
definitely mi16, facelift shape
philhoward
Anyone know the size of the bolts so I can get some??
Paulmi16
x 3
Unread post by Paulmi16 »
Early Mi16 pre-facelift. They are 14 inch compared to the later 15 inch ones. The tyres are likely to be 195x60x14, the 106 GTi uses 185x55x15.
Paul.
silverline
Unread post by silverline »
yep they're definately mi16 wheels! the bolts are a 10mm thread. get bolts from a breakers yard. fords also use the same thread pattern so there aint a shortage of bolts!
philhoward
BTW, Got some brand new GTi-style bolts (with the washer) for £1.70 each; cheaper than s/h ones on ebay! silverline - Peugeot ones are M12x1.25mm; Ford ones are M12x1.5mm - won't fit!
KRISKARRERA
Unread post by KRISKARRERA »
Bear in mind mi16 alloys are ET29..... that is, 29mm offset. They stick in towards the arch closer than other pug alloys. 10mm closer than the 205/309gti alloys for example.
