Paint code for 106
KennyW
x 165
Paint code for 106
Unread post by KennyW »
Hi all,
My friend's laddie drives a Peugeot 106 rusty orange colour :? where is the paint code located on the car. W reg.
Kenny
C3 1.4 petrol (SWMBO)
spider
x 77
Unread post by spider »
From memory, its on the drivers side a pillar. Open the drivers door and look on the pillar.
It 'might' be on the door itself below the latch aperture too.
Probably on the same sticker as the one that indicates tyre pressure.
The (less likely) place is under the bonnet behind or on the strut towers but from memory 106's do not have it here (worth a look if you cannot see it elsewhere)
I know the colour, its quite nice actually :)
Andy.
KennyW
x 165
Thanks Andy,
Is it stamped on or painted on
Kenny
spider
x 77
Its typically just a white sticker about 2 inches long and about an inch high (on the door / pillar)
On the strut top / suspension tower its more likely to be painted on. Be aware the build code is likely to be on the strut tower too, but if you write them all down, wherever you are getting paint / work done they will know which is the paint code.
The only one I can remember is Miami Blue which is M0MY, although that's no help for this case.
Andy.
