Just in follow up to a post I made in another thread, may I just ask any experts and those with greater knowledge than I (that's everyone here, then!) about the resetting of height values following a depressurisation, bleed, new LDS and repressurisation of the system on my C6 which I am now almost certain I require.
I see that the height values can be inputted ( to 6mm either way of a certain threshold?? not sure about this, but think that's right) through measuring at a certain point and performing a calculation against the wheel radius.
As I wish to ft my 20" wheels with summer tyres (8mm bigger diameter than standards ) when I finally get the chance to do the necessary with my hydraulics and LDS, my query is this:
Is there any leeway when inputting the reference heights?
I mean can I deliberately lower the front value in order to close the slighty odd front wheel arch gap, as on the C6 it is inexplicably larger than the rear arch gap, somewhat spoiling the aesthetics of a beautiful car...well it does when you are the owner and spend time being picky about your pride and joy!
Or would that value be critical in terms of ruining any suspension related calculations being performed by the ECU?
Thank you in advance for any insight, Nick
